I have an Archos 604 with Cinema and Video Podcast plug-ins running 1.6.23 Firmware.
I have media converted to .mp4 files using Nero Recode 2 using Cinema AVC.
The video plays fine but I am not getting any audio.
Has anyone had this problem and is there any resolution for it?
What audio codec are you using? AAC? You can identify the audio in a mp4 with mediainfo.
File properties show a
Nero Digital tab and Audio has "High Efficency AAC"
Sample Rate 48000
Average bit rate 160.42 kbps
Not all hardware players support HE-AAC.
Hi You need the correct plugin to decode ACC
http://www.archos.com/products/plugi...try=gb&lang=en
Just got the 705 what a cracking bit of kit
I'm using nero myself with no problemsCHEERS GARRY
Do you encode using Recode Digital AVC?
I have 3 Archos 604 and they are all having the problem.
I have purchased both plug-ins Cinema and Video Podcast for the 604 from the Archos site.
It seems like the Archos 604 does not support MP4-AAC or MP4-AAC.
Looks like it might support MP4-SP.
Because I get the video and not the audio.
Going to try recoding in to a lower format and see if that works.
Hi just looked at the info on my 705 at a Nero file
on video 1
Video is Mpeg 4 592 X 256
AT 698KB/S AT 25FPS
Audio is AAC 79kb/s,44100hz stereo
video 2 mp4 544 x 416 @ 1052kb/s 25fps
audio AAC 159KB/s 48000hz stereo
Hope this helpsCHEERS GARRY
Low audio bitrate problem in H264/AVC cams like Samsung S10 & Sanyo HD2000
By hurry in forum Camcorders (DV/HDV/AVCHD)Replies: 3Last Post: 27th Sep 2011, 05:56 -
[Archos 605] transform from 720p.HD.DVDRip.XviD.AC3 to Archos format ?
By birdwing in forum Portable VideoReplies: 2Last Post: 5th Nov 2009, 23:41 -
Nero Recode for mpg and vob to avi for Archos
By drstew in forum Portable VideoReplies: 3Last Post: 30th Sep 2007, 09:55 -
Archos 404 & DVR stand vs Archos AV 500 - difference in MPEG-4 recordin
By DavidMcGowan in forum CapturingReplies: 0Last Post: 4th Aug 2007, 05:49 -
Does my version of Nero have H.264/AVC ???
By siratfus in forum Video ConversionReplies: 3Last Post: 30th May 2007, 07:15
