i have been trying to determine if this version of dvd fab is compatible with Vista? I went to the site, but couldnt seem to find the answer. I emailed dvd fab.. but have not had a reply yet.
Does anyone know.. ?
If it isnt.. what is a similar product that does much the same and works with vista?
Thank you..
Thread: DVD Fab Platinum 3.08.6 & Vista
It has had Vista support since at last early in v3.x. With that said, it is now up to v4.x, and you would want the latest version regardless.
Google is your Friend
DVD Fab Platinum Frequently Fails, But DVD Fab HD Works. Why ?
By MacPCConsultants in forum DVD RippingReplies: 7Last Post: 4th Mar 2008, 03:39 -
DVD Fab Platinum to HD
By mblanco2000 in forum DVD RippingReplies: 7Last Post: 2nd Mar 2008, 15:50 -
Using DVD Fab Platinum - No sound on last Episode of a Series
By Firewire60 in forum Authoring (DVD)Replies: 2Last Post: 18th Feb 2008, 09:12 -
DVD Decrypter / DVD Fab - Extremely slow ripping speeds in Vista
By awp in forum DVD RippingReplies: 5Last Post: 19th Dec 2007, 13:11 -
Purchasing DVD Fab HD or Platinum ?
By MacPCConsultants in forum DVD RippingReplies: 3Last Post: 1st Dec 2007, 23:21
Statistics
Newest guides
Latest tool updates
New media comments
