VideoHelp.com Forum
    I'm really just getting started in HD formats and was just wondering what are my options when it comes to backing up and authoring HD formats. Can I back them up and burn them to DVD-R's? or DVD-DL? Or do I have to burn them to blank Blu Ray discs? Which are still quite expensive. Or is it best to just invest in some serious hard drive space and store them on hard drives?
    What do you guys do?
    Any help or links to some great starter points on the subject would be great.
    Thanks!
  2. Member ACLUguy's Avatar
    I've yet to use the HDDVD or Blu-Ray formats. So, i may be wrong but i'll try to help.
    As i understand it, hard drive space is still far cheaper than the disks and you can play them off of your computer using a DVI-HDMI cable.
    If you were to shrink them down to the size of a DVD-R or DVD-DL, it seems like it would defeat the purpose of using HD formats, would probably be time consuming and the quality probably wouldn't be as good as playing straight from the computer.
    I'd probably save them on the hard drive and burn them later if you can get some cheap disks. I may be wrong though.
    Just trying to help,
    ACLUguy
  1. I have some questions, Blu-ray license, stamper fee, authoring?
    By T.Shabazz in forum Authoring (Blu-ray)
    Last Post: 23rd Mar 2012, 12:40
  2. Backing up Blu-ray with Hauppauge PVR
    By Doc S in forum Blu-ray Ripping
    Last Post: 20th Jun 2011, 19:16
  3. Backing up my Blu Ray Discs
    By John75 in forum Newbie / General discussions
    Last Post: 6th Jan 2011, 20:27
  4. Backing up blu-ray shortcut
    By alucard2050 in forum Blu-ray Ripping
    Last Post: 1st Dec 2009, 10:10
  5. Backing Up Death Race Blu-Ray
    By mr.adventure in forum Blu-ray Ripping
    Last Post: 14th Jan 2009, 10:18
