VideoHelp.com Forum
Results 1 to 10 of 10
  1. Member LSchafroth's Avatar
    I used to use ColorTools 1.4 in Virtualdub a lot and it worked great.
    I now use Vista Business, with VirtualDub 1.7.7 (stable) and Color Tools 1.4 and when I load it, then click OK to go back to VD for preview it crashes.
    I tried it with VirtualDubMPeg2 1.6.19 and same results.
    Any thoughts?
    Lannie
    An out-of-bounds memory access (access violation) occurred in module 'ntdll'...
    ...reading address 3330E1BE...
    ...while stopping filter "Color Tools [1.4]" (FilterSystem.cpp:651).
  2. Member Soopafresh's Avatar
    Starts with a V and ends with an A...
    Before you switched to Vista, Which version of Vdub did you use? 1.7.7 or a previous version?
  4. Mod Neophyte Super Moderator redwudz's Avatar
    I'm still unclear about ColorTools 1.4. When I do a search, that only seems relate to be a beta version of a program that's used for color conversions and doesn't say anything much about video. Is this the program you are using?: http://rubyforge.org/forum/forum.php?forum_id=19427
    If not, do you have a link? The very latest versions of VD are also beta, so some problems would be expected and not necessarily Vista related.
  5. Member LSchafroth's Avatar
    Dude!! I dont take Viagra....
    Lannie
  6. Member LSchafroth's Avatar
    I had the same versiosn with XP. I just wish I could use it in V...A.
    Lannie
  7. Member LSchafroth's Avatar
    I dontloaded it a long time ago.
    You can grab it off my server. I'll take it down if anyone knows of a reason not too or objects. As far as I know it is free.
    Lannie
    http://www.schafroth.name/clrtools.zip
  8. Mod Neophyte Super Moderator redwudz's Avatar
    I couldn't get it to run either without crashing VD in Vista after coming back from a preview. I suspect it's something in the video handling of the plugin that Vista doesn't like. Doesn't make any difference running VD in XP Compatibility mode either.
    But it does run in my XP Pro computer with no problems. It didn't seem to do anything with my sample video , though. But I'm not familiar with what it's supposed to do. There may be other filters out there that do similar, but don't crash in Vista.
  9. Member LSchafroth's Avatar
    This is my third attempt at getting along with Vista.
    I can get it running pretty darn fast and smooth. BUT, once I start adding my video editing programs and codecs it falls to pieces. Constant rundll errors, explorer.exe crashing. right clicking on a video causes explorer to stop responding. etc, etc.
    I went back to XP, SP3 with the Vista Transformation Pack 8 and it flies. And all my Virtualdub filters work.
    Lannie
  10. Member LSchafroth's Avatar
    Colortools happy once again. Using XP with Vista Transformation Pack 8 and no 3rd party addons.
    Get the look and feel of Vista but the speed and reliability of XP.
    Lannie
  1. Replies: 1
    Last Post: 17th Mar 2012, 02:16
  2. Olympus camera memory card crashes virtualdub
    By snafubaby in forum Newbie / General discussions
    Last Post: 1st May 2011, 00:08
  3. Virtualdub comand line crashes, but virtualdub works.
    By zzyzx2 in forum Video Conversion
    Last Post: 28th Jul 2010, 13:26
  4. Virtualdub Colortools plugin
    By poisondeathray in forum Newbie / General discussions
    Last Post: 1st Nov 2009, 23:20
  5. Virtualdub crashes
    By Kevlin in forum Editing
    Last Post: 18th Jan 2008, 22:01
