VideoHelp.com Forum
Results 1 to 20 of 20
    hi..
    i want to convert DTS audio from a MKV to an acceptable audio for all dvd players..
    can you help me?
    Try DAudioK
    i already tried this program but first i need to extract the audio from the MKV.
    i tried alot programs to exract it but didnt got nothing..
  4. VH Wanderer Ai Haibara's Avatar
    Have you tried the latest version of MKVExtractGUI, with the proper and latest build of mkvtoolnix installed to the same directory as MKVExtractGUI?
    yes..i already tried that too..
    but when i add the MKV file, the video and audio files dont appear.. =/
    i already tried alot programs!!
    i only want to extract the audio but its geting me crazy..
    see in the image what happens when i add the MKV file..
    the video is a H264 MKV with DTS audio
    'file'->'reset'
    half a dozen times
    reload the source,
    half a dozen times.
    until the tracks do show.
    you can also try avimux-gui
    gl
  8. Always Watching guns1inger's Avatar
    Or you could go and buy the disc instead of downloading it. T2 has been widely available for some time, and comes with both DTS and AC3 EX audio tracks.
    Read my blogs here and here. Change England's Libel Laws - Sign Here
    thank you very much 45tripp!!
    this reset and load thing resulted!
    how you found that?lol
    ok..
    after extracting the dts with MKVtools, i used Tranzcode to encode the audio to 6 mono wavs.
    after that i converted the 6 mono wavs to an AC3 file using WAV to AC3 encoder.
    then i usedTMPGenc 3 to merge the AC3 file with the video, but after the output the audio is out of sync.
    suggestions?
  11. Here a complete and simple guide for your question, working 100% fine: http://bit.ly/9D09uI
    Use popcorn mkv audio converter for DTS to AC3 within an MKV file. Set AC3 to 448kbps for greater DVD player compatibility rather than 640. Output will be a 'new' mkv file with AC3 audio. Popcorn also gives you the option to retain the DTS audio within the file (as an additional audio track) if so desired. Excellent tool in my opinion. Please post back your outcome for other users.
    I had problems streaming MKV files with DTS audio using PS3 Media Server through my PS3. I then came across Popcorn MKV audio converter. I converted a few MKV files with DTS audio. The conversion went fine and I was able to play some and got audio but on some files, i get "data corrupted" status on the PS3. On the PC, i get the following message "TsMuxer.exe has encountered a problem" and sometimes it says "Mencoder.exe has encountered a problem". When that happens, the file that is shown on the PS3 becomes "data corrupted".
    Many thanks if anybody knows a way around this. Best regards,
  14. Member ranosb's Avatar
    Use MkvMerge again loading the video & audio(Ac3) file to make a new Mkv video...
    i use tsmuxer to seperate the audio then i use Xvid4psp5 to convert the DTS to AC3 works everytime, then use tmuxer to add the AC3 back in with the video.
  16. Member AlecWest's Avatar
    DaudioK worked for me at first. But just recently, it started getting "runtime error #6 - overflow" errors. So, I tried Xvid4psp5 - but it kept crashing. Popcorn mkv audio converter, however, worked like a Swiss watch. There's some pretty powerful freeware out there, that's for sure.
    Regards,
    J. Alec West
    Reporter: Mr. Hitchcock, is it true you said that actors are like cattle?
    Alfred Hitchcock: I said no such thing. I said that actors should be treated like cattle.
  17. an alternative to popcorn audioconverter, is the open source tool MP42MKVac3
    you can easily use, without much settings
  18. Member AlecWest's Avatar
    Here's a hoot (grin). I recently upgraded my ProCoder version from 2 to 3 ... and now, when I have an MKV file I want to convert to MPEG2, I simply "rename" the MKV extension to AVI. ProCoder 3 recognizes the video AND the DTS audio ... allowing me to convert the DTS audio to AC3 5.1 while the video is converted to MPEG2. And, it all stays in sync.
    Thanks.
    Regards,
    J. Alec West
    Seems to me that is much easier to open the mkv with
    Pazera Free Audio Extractor and choose whatever conversion
    you need from the output format menu.
  20. The best an better freeware to convert your audio DTS to AC3 is the MKV2AC3. Works totally fine for me. See more here: http://bit.ly/mkv2ac3
  1. MKV - DTS to AC3 nightmare
    By aaron1104 in forum Audio
    Last Post: 8th Mar 2012, 15:16
  2. Replies: 5
    Last Post: 31st Dec 2011, 08:02
  3. How i can convert dts-es to dts-core from one mkv file?
    By fits79 in forum Video Conversion
    Last Post: 11th Jun 2011, 21:24
  4. Replies: 5
    Last Post: 3rd Jun 2011, 08:17
  5. MKV - DTS to AC3 nightmare
    By aaron1104 in forum Video Conversion
    Last Post: 11th Oct 2009, 03:17
