I have a Oppo DV-981HD dvd player and I just recently bought an Onkyo TX-SR605 receiver. I wanted to run the audio and video through HDMI, but for some reason the sound was really low when I connected it. So I went back and hooked it up with an Digital Optical connection and now it sounds great. Is there any way to hook up this DVD player through HDMI and have great sound?
Have you setup the audio settings properly in the Oppo audio setup menu? Suggested settings begin on p.23 of the manual.
Google is your Friend
I tried everything, but I'll check the manual thanks!! I was wondering if anyone has this DVD player with this receiver so I can get some more specific suggestions.
I suggested the manual because from past experience, setting the correct speaker size (among other things) affects the sound levels. I would start with what is in the manual which is specific for audio over HDMI. If that doesn't solve the problem, contact Oppo (they have great tech support) or hit the AVS forums as the Oppo units are covered well over there.
Onkyo TX-SR605 shaky on 1080i/p component
By Hunterx82 in forum Newbie / General discussionsReplies: 0Last Post: 10th Jan 2011, 09:11 -
OPPO DV-981HD shuts itself OFF
By ms.zebra in forum DVD & Blu-ray PlayersReplies: 0Last Post: 2nd Nov 2010, 22:42 -
Hack for OPPO DV-981HD- Region 1 vs. 2?
By ms.zebra in forum DVD & Blu-ray PlayersReplies: 9Last Post: 18th Sep 2010, 07:34 -
Can't display subtitles on some movies - OPPO 981HD
By uderman in forum DVD & Blu-ray PlayersReplies: 12Last Post: 8th Dec 2009, 18:26 -
Oppo 981HD HDCP hack question
By MisterEd in forum DVD & Blu-ray PlayersReplies: 14Last Post: 9th Feb 2009, 20:59
Statistics
Newest guides
Latest tool updates
New media comments
