VideoHelp.com Forum
Results 1 to 11 of 11
    I have made a DVD that contains a Firstplay Video. MPC shows the firstplay but VLC does not. Any idea how to get it to show the video? Thanks
    Bump
    Anyone?
  3. Member Kayembee's Avatar
    What the heck is a "Firstplay Video"?
  4. I think what he is saying is the first video intro, fbi warning on a authored dvd VLC ignores and goes straight to the menu. I think this is by design. If you are trying to test a dvd you may want to look at power dvd.
    I have seen the behavior you mention, and I am not aware of any work around.
  5. firstplay video...is this a (short) video that plays prior to the menus?
    Thats exactly what it is. I authored the DVD with TDA3 which allows you to add a firstplay clip aka intro clip.
  7. Member Krispy Kritter's Avatar
    Have you tried another program to test besides VLC as noted above?
    Google is your Friend
    Yes I have. MPC shows the firstplay video but VLC is my player of choice.
  9. Member Krispy Kritter's Avatar
    Nothing there.
  11. Member Krispy Kritter's Avatar
    Well if anyone can answer your question, I would expect it to be someone in the VLC forum. Aside from that, it sounds like it is just the way VLC handles DVD playback. And knowing that it doesn't playback DVD the way you want, you now know not to use it to verify your projects. Knowing is half the battle.
  1. Replies: 29
    Last Post: 23rd May 2012, 05:06
  2. UOP for FirstPlay
    By grzegorz in forum Authoring (DVD)
    Last Post: 9th Apr 2008, 07:58
  3. vlc alternative
    By ecos in forum Newbie / General discussions
    Last Post: 21st Feb 2008, 04:28
  4. DVD Remake Pro deletes my firstplay?
    By lordsmurf in forum Newbie / General discussions
    Last Post: 18th Jul 2007, 02:10
  5. MPC v. VLC
    By Ogilvy in forum Software Playing
    Last Post: 7th May 2007, 09:05
