I can play videos with subs when the sub name is the same as the file name however I cannot turn them off. I have my output set to DirectShow VRM7/9 Renderless. As the video is playing, i right click and the subtitles menu is greyed out. I installed Vobsub to see if that would fix it but no luck. Any other thoughts? Thanks
Results 1 to 12 of 12
Thread: MPC and SRT subs
Have you checked under Play->Subtitles and Navigate->Subtitles and Play->Filter->vobsub/vsfilter ?
Under play, the subtitles menu is greyed out.
Bump
Anyone?
Are you actually using MPC or the mplay2.exe from XP?
Google is your Friend
Sometimes you have to select vmr 7 renderless to get the subtitles to not be grayed out.
Yes I am actually using MPC. I do have VRM7 Renderless as my 1st post stated. Thank you.
Do any other icons show up in your taskbar tray when you're playing a video with subs, such as a slightly-curved green arrow?
yes I get 2 icons. Red ffshow icon and the green arrow icon you mentioned.Originally Posted by Ai Haibara
Okay, the green arrow indicates you have (Direct) Vobsub installed. Right-click on it, and there should be some subtitle stream options as well.
ffdshow also has subtitle options, but it's less likely to be the culprit... so if experimenting with Vobsub's subtitle stream options doesn't help, check ffdshow's options (in the video decoder/VfW options).If cameras add ten pounds, why would people want to eat them?
Ok, clicking on the green arrow allows me to turn the subs on and off so mission accomplished. Is there a way to control the subs from within MPC or is this how I am stuck doing it?
Subs visible in MPC but not in tv?
By stargazer500 in forum SubtitleReplies: 4Last Post: 18th Nov 2011, 15:43 -
MPC-HC displays two lots of subs overlapping?
By snadge in forum Software PlayingReplies: 3Last Post: 23rd Jul 2011, 12:00 -
playing .MKV file in MPC Home Cinema, no subs
By THX-UltraII in forum Newbie / General discussionsReplies: 1Last Post: 15th Aug 2008, 07:22 -
Supports .srt subs? Or not?
By Tabula Rasa in forum SVCD2DVD & VOB2MPGReplies: 5Last Post: 13th Aug 2008, 12:00 -
Subs play in MPC but not on disc
By pzoggy7 in forum SubtitleReplies: 3Last Post: 13th Nov 2007, 10:03
