Hi all,
Can anybody help me out to convert the MPEG 1 to H.264 video. Please also tell what will be the audio format ?
Waiting for reply asap![]()
Sarvagya
Thread: MPEG1 to H.264 conversion
The easiest way to do this, is through SUPER encoder.
You can choose framesize, audio, etc.
It is usually .AAC
I tried it with the Media Coder, successfully i converted the video but the problem is with the audio although i used the .AAC format.
Hello,
I would suggest WinFF, Better output quality than SUPER, far simpler and more stable than Media Coder and way lighter footprint on the system. There are several H.264 presets, even the iPod ones are optimized for TV Out use and are quite good for general use, I use it to convert VCD MPEG-1 files to H.264 all the time.
Lossless Conversion from AVI H.264 to MP4 H.264
By kenchen in forum Video ConversionReplies: 3Last Post: 22nd Oct 2010, 14:04 -
.264 Conversion
By thunderclap82 in forum Video ConversionReplies: 4Last Post: 11th Mar 2010, 17:48 -
Looking for H.264 conversion help
By fordprefect138 in forum DVD RippingReplies: 9Last Post: 24th Nov 2009, 05:19 -
H 264 conversion
By Russo in forum Video ConversionReplies: 95Last Post: 8th Oct 2009, 16:38 -
H.264 (MOV) to H.264 MPEG TS conversion
By svens in forum Video ConversionReplies: 0Last Post: 19th Feb 2009, 06:47
