I bought a japanese DVd recently but made a mistake, as it had no english subtitles. In an attempt to fix this i downloaded an .MKV file of the same movie w/eng subs and believe i successfully extracted the Sub file with THIS. This was done so i can backup the movie and add the sub file to it.
Now I need help with #1: Converting the .Mkv subtitle file to a format the typical DVD author program will accept, #2. editing the subtitle file a bit so that it matches up well with what is on-screen, and #3: Adding it to the movie during backup.
Any good programs out there which can do this, preferably easy?
Any help would be greatly appreciated.
1. MKV can contain different kind of subtitles. Doesn't mkvextractgui list what kind it is? Can you read the subs if you open it notepad?
2. If text subtitles you can open and edit subtitles workshop, subtitle creator.
3. Add back to new dvd using subtitle creator, see http://forum.videohelp.com/topic338721.html
And this is more a subtitle issue. Moving you.
Yeah when making this thread i was not sure what section to put it in.
How to extract subtitles from MKV videos to convert them to AVI
By zikegi in forum Video ConversionReplies: 0Last Post: 15th Sep 2011, 20:47 -
AVCHD (DVD) .ISO file, trying to extract original MKV from DVD image
By SkEvolver in forum Blu-ray RippingReplies: 12Last Post: 11th Aug 2011, 05:55 -
Convert from MKV to AVI (mpeg-4 codec) + add subtitle to the video file
By kovacic_10 in forum SubtitleReplies: 3Last Post: 19th Feb 2011, 17:38 -
Extract from avi file and add to existing mkv file
By pathumx in forum MacReplies: 6Last Post: 8th Apr 2010, 18:57 -
By SkEvolver in forum Authoring (DVD)Replies: 1Last Post: 3rd Jul 2008, 20:34
Statistics
Newest guides
Latest tool updates
New media comments
