I've recently run into two XviD files that would not play correctly on my Philips DVD player, even though they looked fine on my PC.
My usual method is to burn a DVD using Deep Burner in the CD File mode (No multisession), and select the file from the player's menu.
After snagging all the episodes of the "Tin Man" SciFi series, I whipped up a DVD and enjoyed two out of the three parts. The third file had blocky video.
I have already reencoded and reburned the DVD, so I'm not going to ask how to fix the problem. Rather, I want to be able to identify future problems before burning the disk.
I thought the problem might be GMC/QPEL related, as that is a known limitation with the Philips player. But, after squeezing the info out of the offending file (with GSpot), I see that GMC and QPEL are not being used.
The only significant difference between the two good files and the one bad file is the codec:
Good codec = XviD 1.1.2 Final
Bad codec = XviD ISO MPEG-4
The same (blocky video) symptoms showed up again with a file that was encoded using "XviD 1.1.0 Beta 2".
Does anyone know of any problems with these codecs as releated to the Philips player? Is there another file aspect that could be the cause?
Here is a table showing the file particulars according to GSpot. Blank entries and Audio information were removed.
Code:FILE_NAME tin.man.part.1.avi Tin.Man.Part.2.avi Tin.Man.Part.3.avi FILE_SIZE 735,733,760 734,294,016 734,218,240 CONT_AUDIO_STREAM_COUNT 1 1 1 CONT_BASETYPE AVI(.AVI) AVI(.AVI) AVI(.AVI) CONT_BYTES_MISSING 0 0 0 CONT_INTERLEAVE_ALIGN Aligned Aligned Aligned CONT_INTERLEAVE_PRELOAD 504 504 504 CONT_INTERLEAVE_TIME 42 42 42 CONT_SUBTYPE OpenDML (AVI v2.0), OpenDML (AVI v2.0), OpenDML (AVI v2.0), CONT_TOTAL_BITRATE 0 0 0 VIDEO_BITRATE 985 1018 1041 VIDEO_CODEC_NAME XviD 1.1.2 Final XviD 1.1.2 Final XviD ISO MPEG-4 VIDEO_CODEC_TYPE XVID XVID XVID VIDEO_DAR 1.773 1.773 1.773 VIDEO_DURATION 1:27:25 1:24:39 1:23:38 VIDEO_FRAME_COUNT 125749 121759 120311 VIDEO_FRAMES_PER_SEC 23.976 23.976 23.976 VIDEO_MPEG4 MPEG-4 MPEG-4 MPEG-4 VIDEO_MPEG4_BVOP B-VOP B-VOP B-VOP VIDEO_PAR 1 1.000 1.000 VIDEO_PICS_PER_SEC 23.976 23.976 23.976 VIDEO_QF 0.187 0.193 0.198 VIDEO_SAR 1.773 1.773 1.773 VIDEO_SIZE_X 624 624 624 VIDEO_SIZE_Y 352 352 352
The following things can be problems on any DVD player that supports Divx/Xvid:
1) GMC (rarely supported and if it is supported, ONLY for 1 warp point, despite claims to support 3 warp points)
2) QPel (Quarter Pixel)
3) Packed bit stream (the Philips DVP-642 absolutely will NOT play these files, if that's your player model. Fix with MPEG4Modifier.)
4) Resolutions greater than 720x576
5) Video bit rates above 2000 Kbps. In fact, some chips will require your video bit rate to be as low as 1400 Kbps or maybe less if your audio is anything other than MP3).
File sizes larger than 2 GB can also have playback problems. Philips DVD players typically don't have issues with VBR MP3 playback, although other player may.
If your audio is AAC, that MIGHT be a problem, although usually Philips players just play these files silently rather than not at all. If your files are not in an AVI container, this can also be a big problem. Some Philips players won't touch MP4 containers. Others will.
I'd look for file sizes larger than 2 GB and packed bit stream as the likely causes of your issues. Also check to see if your files are in MP4 containers (most likely their names will end in .MP4). Whatever your problem is, it is definitely NOT a codec issue. -
My only thought (after reading a similar post earlier today) would be B-VOP. The other user found information stating players have problems with files containing more than a single B-VOP. I don't know if it is true or not, just something for you to investigate.
Google is your Friend -
Using Quantisation Matrices other than the standard 2 produces AVIs that won't play well in ESS chipset DVD/MPEG-4 players. You get these colored blocks which may be what you experienced.
How to reconvert an AVI with AutoGK, remove QPEL, GMC etc
By Baldrick in forum User guidesReplies: 35Last Post: 10th Jan 2010, 22:00 -
Philips DVP 5960/12 reports GMC NOT SUPPORTED
By sound grammar in forum DVD & Blu-ray PlayersReplies: 11Last Post: 2nd Apr 2009, 20:27 -
So has anyone invented a player which does Xvid GMC yet?
By arromdee in forum DVD & Blu-ray PlayersReplies: 2Last Post: 4th Apr 2008, 08:00 -
xvid with QPEL
By ekyfetweky in forum Newbie / General discussionsReplies: 3Last Post: 22nd May 2007, 20:14 -
XviD: Qpel, GMC, Max consecutive B-VOPs, and N-VOP ??
By GangstaRap in forum Video ConversionReplies: 17Last Post: 20th May 2007, 03:59
