I am having trouble locating the code to get the digital box to recognise the Polaroid DRM-2001G. No info on the Motorola card, at my cable company that installed the box or using the auto find feature. Anyone know this code?
What do you mean by "recognize"? How do you have them connected? You should be able to connect the video output of the digital box into the video input of the Polaroid.
Google is your Friend -
The installation guy said everything has to run thru the digital box. Is this true? If I connect the cable to the digital box and then the digital box output to the input of the DVR I need to have the code to get the DVR to work. There is supposed to be a 4 digit code, and there is for about every other manufacturer but not for the polaroid.
Are you talking about a remote code? Otherwise I don't know what code you're talking about.
The DVR will work just fine on its own. However, the Polaroid is likely unable to tune your cable channels on its own. Channel tuning will need to be performed by the digital cable box. In which case "everything has to run through the digital box".Google is your Friend
Look what I found-a Motorola DCH3200 set-top box for use with Comcast cable
By zoobie in forum DVB / IPTVReplies: 7Last Post: 15th Dec 2010, 20:27 -
Problem: DVD-R Recording with Motorola QIP6416-2 DVR FiOS TV Box
By Plarocks in forum DVD & Blu-ray RecordersReplies: 12Last Post: 4th Jun 2010, 19:03 -
3 Digit manufacturer's code for Toshiba SD-V395KC
By Snakebyte1 in forum Newbie / General discussionsReplies: 1Last Post: 7th Apr 2009, 10:15 -
Is there a Western Digital external harddrive for motorola dvr's?
By yoda313 in forum CapturingReplies: 0Last Post: 23rd Feb 2008, 15:55 -
Code is not working on Polaroid PDX-0073, HELP!
By Joppie in forum DVD & Blu-ray PlayersReplies: 2Last Post: 23rd Sep 2007, 12:46
