VideoHelp.com Forum
  1. I am having trouble burning this to DL:
    Über Series Volume 28 / Uber Series DVD VOlume 3
    Title: The Lost 1993 TV Special
    Date: 1993-05-28 Stockholm Stadion, Stockholm, Sweden
    (tracks marked with "*" 1993-05-22 National Bowl, Milton Keynes, UK)
    Format: 2 DVD9/dual layer's
    Video format: PAL 16:9 Widescreen
    Audio info: Raw TV Special tapes DVD dump. Some click/pop removal, specially towards the end,
    light noise reduction, some light compression to even out source differences,
    cleaned up transitions between sources and normalized in Audition 2.
    Finished wav files split with CD Wave 1.95.1 and compressed to FLAC with
    FLAC 1.1.4 trough FLAV frontend 1.7.1. Tags added with MP3Tag 2.37a
    Video info: Video has gone through a lot on it's way from the original XP mode transfered source discs.
    Here's a quick lineage/effect chain. More of a effect chain since some of the steps hare lossless
    while others of course are lossy. But the original did need cleaning up.
    original mpegs->patched aspect ratio header from 16:9 to 4:3->cut out each different segment that had differently
    placed letterboxing->cropped out the letterboxing in Avisynth->Ran the Avisynth script trough an addaptive
    deinterlacer script->fed that progressive video to a upscaler/resizer to get 720x576 anamorphic video->Huffjuv AVI->
    Cinema Craft Encoder SP2 at 8000kbit/sec constant bitrate->re-merged the segments in Womble MPEG VIdeo Wizard-> authored
    in DVD Lab Pro 2
    Burning info: There are no layer breaks set in the IFO files of this post but there should be chapters and/or cells in the right
    for any burning program to burn it properly. I recomend using ImgBurn in it's Build mode. Drag over the VIDEO_TS
    folder, set a layer break point when the program asks and hit burn.
    I would recomend a layer break fir disc 1 at Chapter 11/Cell 11. That is right before My Hometown. For disc 2 I
    would recomend setting the layer break at chapter 10/cell 10. That's just before Thunder Road. Some programs might
    not like that spot for disc 2 tough so a extra cell has been added to the middle of Thunder Road to be used as a
    layer break by picky programs.
    I am using nero 6 rom. It is burning at 2.4X and it fails at about 4-5 minutes into burning. Can anyone please help me with this fromblem? Do I need to adjust some setting on the nero? IS there a better program (possible free program). I also have ulead 4.0 moviefactory on my computer to use.
  2. Mod Neophyte Super Moderator redwudz's Avatar
    I'm not sure exactly what you are asking, but I would never use Nero for burning DL discs. The freeware ImgBurn is one of the best burning programs out there for DL. And if you use anything but Verbatim DL + DVD discs, your odds are not good for getting a good burn.
  3. Member dadrab's Avatar
    Why would you build with ImgBurn and burn with Nero? As redwudz says, burn it with the same application.
  4. Member oldandinthe way's Avatar
    My guess is that you are not using Verbatim media. Failing during a burn is common with Ritek and Ricoh DL media.
  1. trouble backing up dvds to external hard drive (on PC)
    By duquesne in forum Newbie / General discussions
    Last Post: 25th Dec 2010, 08:32
  2. Replies: 0
    Last Post: 8th Oct 2010, 19:40
  3. Having trouble burning from hard drive to DVD
    By becassier in forum Authoring (VCD/SVCD)
    Last Post: 5th Nov 2008, 12:33
  4. DVD Burning And Hard Drive Backing up..
    By Mastablastacious in forum Computer
    Last Post: 19th Jan 2008, 02:30
  5. Replies: 1
    Last Post: 17th Dec 2007, 11:07
