Is it possible to convert the h.264 digital format to PAL, SECAM, NTFC formats in DirectShow ?
i want to send the digital video to a TV Tuner and display it on TV, is it possible ?
Connect the s-video or composite output from your graphics card to your TV. Enable TV output in the graphics card's setup applet.
If your graphics card doesn't have TV output you can use something like the device mentioned in this thread:
http://forum.videohelp.com/topic341784.html
That will convert VGA to s-video or composite. I don't now if that particular device supports the output video standards you need.
If you really require RF (ie using a tuner on your TV rather than s-video or composite) you'll need an external RF modulator.
can a PAL disc work fine in a SECAM system ?
By Bansaw in forum Newbie / General discussionsReplies: 5Last Post: 20th Mar 2012, 04:55 -
h.264 encoder with directshow support
By sampalmer21 in forum Video ConversionReplies: 1Last Post: 3rd Nov 2009, 09:52 -
PAL DVD work on SECAM?
By BobAchgill in forum Authoring (DVD)Replies: 3Last Post: 4th Aug 2009, 06:20 -
VHS capture jumping between PAL and ME SECAM...help
By pijetro in forum CapturingReplies: 2Last Post: 21st Feb 2009, 18:55 -
how do I programmatically choose H.264 encoding; ffdshow in directshow?
By kimvette in forum Video ConversionReplies: 5Last Post: 12th Nov 2008, 16:42
Statistics
Newest guides
Latest tool updates
New media comments
