  1. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    My computer slots are full. Any suggestions for occasional TV to computer capture via USB?
    I wanted a Hauppauge 250 or 350 to build a PVR but...I'm looking for other options.
    I have a spare computer to build a PVR but I'm not sure how much it would get used.
  2. How about an external hard drive? You can get a 250 gb for under $100 these days.
    What does a hard drive have to do with a capture question?
  4. Mod Neophyte Super Moderator redwudz's Avatar
    USA
    Hauppauge does have some USB products: http://www.hauppauge.com/pages/prods_usb.html No experience with them, but their other products are popular.
  5. Member edDV's Avatar
    Mar 2004
    Northern California, USA
    Check the supported tuner list for the software you plan to use. Check user forums for that software.
    The WinTV-PVR-USB2 is probably the most supported USB tuner.
    http://www.kiva.org/about
  6. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    SORRY....this problem has been solved. I bought a PVR-350 and removed a card that had 4 USB ports on it....leaving me with 6 USB ports.
