VideoHelp.com Forum
Results 1 to 15 of 15
    Let me preface by saying I completely understand the difference between stereo and mono.
    My Hi8 camera only has a mono out and so all this stuff I cap'd is only coming from one speaker.. Im trying to figure out how to convince Virtualdub to duplicate the audio onto the other speaker..
    I tried simply choosing stereo under Audio>Conversion .. but that didnt do it..
    is there an easy-ish way of accomplishing this?
    thanks,
    nopk
  2. Mod Neophyte Super Moderator redwudz's Avatar
    Sort of...........
    You can demux or extract the audio to WAV and open it in Audacity or similar, then 'clone' the existing channel to a second channel and output as a stereo track. If you want to get 'fancy', you can modify both channels with reverb or other subtle changes and get closer to a stereo 'effect'. Then you can add or 'mux' the audio back with your video.
    I don't know the output format of your camera. MPEG or AVI type? AVI, you can demux or extract as a WAV with VirtualDub or similar. VD Mod can also extract from a MPEG. Then after processing with Audacity or similar, you will have to mux or add it back with the video. Depends on what end format you want.
    There are other tools and methods, but that one works for me most times. Good new, it's all freeware.
  3. Easiest way is to get a mono to stereo adapter, these are available at you local electronics store. If you're in the US Radio Shack always has them.
    I don't use Vdub that much but you can extract the audio track, then use Audacity to convert to stereo.
    damnit. I knew I shouldve just built a stereo/mono adaptor before I started caping all this the other day.. but figured "how hard could it be to fix in software" ..
    camera is an analog hi8.. so.. output format is nothing.
    thanks for the tips, I'll look into ripping the track off and cloning it..
    nopk
  5. Mod Neophyte Super Moderator redwudz's Avatar
    It's not that hard. Audacity inputs and outputs WAV, MP3, Ogg and a lesser known format I forget. But WAV is fairly universal. You can save it out from Audacity again as a WAV, then convert it to different formats. I use ffmpeggui to convert it to AC3 format. Then I use that with the video in a authoring program and output as DVD format. Or if you use TMPGEnc encoder, you can input the video and WAV audio and the program can convert the audio to MPEG-1 Layer2 as it encodes the video to MPEG-2.
    Just a few options.
  6. Member hech54's Avatar
    Reaper
    Load the mono wave twice on separate tracks, play around a bit with them then render them. It's a fun and easy program....REALLY.
  7. Originally Posted by nopk
    Build? There like $5 US.
  8. I'm a Poll Super Moderator johns0's Avatar
    $1 at the dollar store
    Ben Johnson-I didnt take any stereos!
    yup.. but at 7 pm on a tuesday theres not a radio shack open around here.... and Ive got everything I need around here to slap one together..
    Brett
  10. Banned
    nopk, any wave editor will let you create either real stereo (in your case it'll be dual mono of course) or a joint stereo file from your mono file.
    You dont need to buy any expensive soft, even i.e. Nero's own built-in Wave Editor is capable of this.
    Its a very simple process, there is no quality loss or anything.
  11. Or instead of an adapter just buy a simple mixer. Behringer do some inexpensive good quality ones.
    http://www.behringer.com/802/index.cfm?lang=eng
    It's much easier to fine tune volume levels using a mixer than the Windows volume control. You can pan the signal left or right. I think with just a signal plugged into the left input it feeds to both channels automatically anyway.
  12. Member dphirschler's Avatar
    Use AviSynth. Try this simple script:
    vid=AviSource("myvideo.avi")
    audioL=GetChannel(vid,1)
    audioR=GetChannel(vid,2)
    audio=MergeChannels(audioL, audioL)#
    return AudioDub(vid, audio)
    You can change the line marked with '#' to use the right channel, or to swap L and R.
    Darryl
    thanks for this.. I played with it a bit last night.. the generated channel (L) seems slighty different than the original channel (R) .. higher volume? or cleaner maybe? not sure.. but not a big deal... Im listening to it with headphones so I probably won't notice on speakers..
    Im curious though.. did you mean the # marked line to read:
    audio=MergeChannels(audioR, audioL)
    or the audioL,audioL you posted..
    I tried reading the syntax for the mergechannels command at the avisynth website.. but couldnt quite wrap my head around it.. http://avisynth.org/mediawiki/MergeChannels .. I think as Ive no experience with the terms etc.. or maybe Im just slow
    thanks for the help,
    nopk
  14. Member gadgetguy's Avatar
    nopk
    dphirschler meant to to use audioL for both positions. The Getchannel(vid,1) means get the left channel of the audio in video clip "vid", GetChannel(vid,2) means get the right channel of the audio. You said you were only hearing audio out of one side, but didn't specify which side. His example uses MergeChannels to put the left channel on the left side and also on the right side. If it turns out that the audio is actually coming out of the right side, then use MergeChannels(audioR, audioR) to put the audio from the right channel on both sides'
    Buy My Books
    ah ha.
    When I saw merge I assumed it had to merge 2 things.. so therefore merging left with left didnt make sense. In my case, I have right channel, so I'll do audior and audior and be rockin.
    thanks for the clarification..
    nopk
  1. Create video file that allows pseudo streaming
    By gffb in forum Video Streaming
    Last Post: 21st Jul 2011, 23:07
  2. FFmpeg / FFmbc ---> 8 Mono track to 1 Stereo
    By elmuz in forum Video Conversion
    Last Post: 13th Jun 2011, 06:06
  3. Replies: 0
    Last Post: 22nd Feb 2011, 14:31
  4. Where Can I Buy a mono-stereo 3.5 mm mono to stereo L-adapter?
    By solarblast in forum Camcorders (DV/HDV/AVCHD)
    Last Post: 26th Nov 2009, 05:45
  5. Creating a Pseudo 5.1 Mix from Stereo Source Using V.I.
    By guns1inger in forum User guides
    Last Post: 27th Jul 2009, 17:21
