VideoHelp.com Forum
    If I have a avi, divx, etc file, what is the best way to convert from 720p to 480p?
    Because 1280x720 --> 720x480, doesn't really scale correctly. Is there some way I can scale 1280x720 to 720x480?
    Does that mean I have to cut some footage off or make a bars on top and bottom? How do I do that?
  2. I'm a Poll Super Moderator johns0's Avatar
    You would make bars.1280x720=720x405+38,38,so you would need to add 36 pixel bars horizontally.You will need to re-encode.
    Ben Johnson-I didnt take any stereos!
  3. Because 1280x720 --> 720x480, doesn't really scale correctly. Is there some way I can scale 1280x720 to 720x480?
    I'll assume you're converting for DVD. It really does scale correctly. 1280x720 is 16:9. Do a straight resize to 720x480 and encode for 16:9.
    720p sources are 59.94fps, as I'm sure you know. Unless the duplicate frames were removed before you got it, you'll also have to get it down to 29.97fps or (better, if possible - if it's a movie) 23.976fps.
  4. I'm a Poll Super Moderator johns0's Avatar
    If the avi is a proper 1280x720 then it will scale to 720x480 but if it was done improperly like lots of avi are done then you will need to add borders.
  1. How do i make a 480p video to 720p?
    By brotherhood1997 in forum Newbie / General discussions
    Last Post: 7th Dec 2011, 11:36
  2. 480p to 720p
    By Ally68 in forum Newbie / General discussions
    Last Post: 9th Dec 2010, 17:09
  3. What's the deal with # of p? 480p, 720p, 1080p?
    By Inertially in forum Newbie / General discussions
    Last Post: 30th Oct 2010, 10:25
  4. Help Resizing 720p » 480p
    By Enkidu in forum Newbie / General discussions
    Last Post: 27th Jul 2010, 13:17
  5. How to convert a 720p BBRIP to 480p avi (& keep 5.1 audio)
    By andyh1 in forum Newbie / General discussions
    Last Post: 24th Jul 2010, 16:02
