Ok, back again with another conversion need. My father has the RCA DVD Recorder DRC8052. Need the following for iriverter/KawaiiRiver for optimal conversion:
maxVideoBitrate=?
maxAudioBitrate=?
dimensions=?
Thanks!
MKV: Merely Krappy Video.
Subbers, a request from an avid viewer: Either don't use mkv, or supply avi or mp4 as an alternative.
For those frustrated with converting MKV: http://www.immortalmusic.net/mkv/
Should be the same specs as for your other player conversions. (At least I think it was you wanting the file specs for a Philips unit). The same basic guidelines apply for all Divx players. So once you find specs that work on one, they should work on them all. (assuming basic players like the Philips 642)
Edit: Basic guidelines (borrowed from jman) for things to avoid:
1) GMC (Global Motion Compensation). Some support it up to 1 warp point. Some don't support it at all. If it's used during encoding, it probably has 3 warp points and no standalone DVD player at this time appears to support that. Despite some claims to support it, I've seen reviews where 3 warp point GMC was tested and it always failed.
2) QPel (Quarter Pixel)
3) Packed bitstream.
4) Resolutions greater than 720x576.
5) Video bit rates higher than 2000 Kbps. With some Divx playback chips, if your audio is anything other than MP3, you may have to drop the video bit rate as low as 1400 Kbps or you may have audio playback problems
Also, if you use AutoGK, it has an option for making files compliant for Divx players.Google is your Friend
Ok, Thanks!
Batch conversion AVI (DivX) to H.264?
By hagin in forum Video ConversionReplies: 1Last Post: 2nd Sep 2010, 05:29 -
TMPGEnc DivX conversion BLOCKED-LIKE avi
By visitor in forum Video ConversionReplies: 2Last Post: 26th Dec 2009, 10:32 -
.divx to .avi XviD conversion?
By Benhermies in forum Newbie / General discussionsReplies: 2Last Post: 3rd Feb 2009, 18:15 -
DIVX to AVI conversion
By jjbodean1970 in forum Video ConversionReplies: 9Last Post: 18th Aug 2008, 00:05 -
The New RCA DRC8052
By grandmasterjayboogie in forum DVD & Blu-ray RecordersReplies: 12Last Post: 8th Apr 2008, 23:33
Statistics
Newest guides
Latest tool updates
New media comments
