VideoHelp.com Forum
  1. curious about the following:
    What program do you use to import the video in Windows,
    What kind of file names do you get for the imported clips,
    What program and codec do you use to compress the final video /Can VirtualDub MPEG work with the raw files?
    Thanks!
    HDVSplit
    mt2
    I don't know if virtualdubmpeg2 support those.
    MPEG-VCR will convert an m2t file to an mpeg without re-encoding.
  4. Member edDV's Avatar
    I mostly use Vegas (v6d, v8) but have used HDVSplit and CapDVHS. Both worked. I've yet to try Vista's Windows Movie Maker which is supposed to support HDV.
    http://www.kiva.org/about
  1. HV40: Record in HDV(PF24) vs HDV(24F)
    By videobread in forum Camcorders (DV/HDV/AVCHD)
    Last Post: 23rd Dec 2011, 20:44
  2. Capturing HDV Tapes using a DV Camcorder
    By Raz1 in forum Capturing
    Last Post: 18th May 2011, 15:49
  3. How to import HDV tapes to hard drive for archival
    By SteveCA in forum Video Conversion
    Last Post: 25th Aug 2010, 00:26
  4. From HDV shooting to HDV watching
    By MI6 in forum Camcorders (DV/HDV/AVCHD)
    Last Post: 26th Apr 2008, 13:05
  5. HDV tapes
    By mikehorne in forum Camcorders (DV/HDV/AVCHD)
    Last Post: 1st Aug 2007, 03:29
