Results 1 to 10 of 10
    Hello all,
    I'm trying to use .sup and .sup.IFO files to subtitle a movie (presently mpeg from EyeTV recordings, demuxed by ProjectX). I just need to be able to read the subtiles on top of the video, either adding it to DVD VIDEO_TS folder or directly encrust in a divx avi.
    Converting these files to .str format will also help me.
    Any help on finding Mac softwares which can handle these file format will be welcome.
    Phil
  2. Member terryj's Avatar
    Don't know if it will, but have you tried TitleLab?
    "Everyone has to learn, so that they can one day teach."
    When I'm not here, Where can I be found?
    Urban Mac User
    Thank you for the idea, I just test TitleLab but it does not recognize my sup files. It works great on str subtitles files.
  4. Member terryj's Avatar
    yes I use it to make .srt subs into DVD Studio Pro Compatible .stl
    files all the time. It's the most robust subtitling program on the mac side, thought it might be worth a shot. sorry.
    Urban Mac User
    Do you mean DVDSP is able to convert my .sup file into .str one ?
  6. Member terryj's Avatar
    No.
    The files must be in .STL format for import into DVDSP.
    DVDSP will not use .sup files, nor does it convert sub streams
    into its .stl format. The files need to be in .stl format to use in
    DVDSP.
    Urban Mac User
    Ok Terry, I got it.
    I mistaked .srt and .STL (that I never heard about)
    No way to use these .sup files ! On Macintosh I mean.
    I will have to look on the dark side of computeurs : gotta see what PC soft can do the job.
    Thanks a lot anyway
  8. Member terryj's Avatar
    u r welcome.
    One other trick I use, when there aren't convertable
    subs attached to a movie that I need, but that are playable
    and watchable in say VLC, is to Play the movie in VLC
    with the subs on, and then make iShowU "hijack" the movie
    as it plays in realtime to a DV Stream file.
    This way, I have the movie, with the subs "burned in",
    in a DV Stream that I can drag and drop into FCP or iMovie,
    edit as necessary, and then burn to DVD.
    I don't have to do this often, only for movies in which I can't google
    and find the subs ( in .srt format) for. It does require a bit of HD space to do so also.
    Urban Mac User
    Amazing !
    Didn't know we could hijack also the video!
    If I did not find a solution I'll try it, as VLC can read my mpeg and subtiltes.
    thanks
  10. Member terryj's Avatar
    u r welcome!
    Urban Mac User
  1. Replies: 4
    Last Post: 20th Aug 2007, 14:38
  2. how do you burn the VIDEO_TS.IFO files with other softwares?
    By Beautiful Alone in forum DVD Ripping
    Last Post: 16th Dec 2003, 18:19
  3. Ifo Update.. problem merging the 2 ifo files
    By SidDan in forum DVD Ripping
    Last Post: 18th Nov 2003, 13:40
  4. Replies: 1
    Last Post: 15th Nov 2002, 14:36
  5. how do I create multiple IFO files in IFO Edit?
    By marisag427 in forum DVD Ripping
    Last Post: 12th Nov 2002, 02:58
VSO Software ConvertXtoDVD lets you convert any video like AVI,MKV to DVD easily. More info or download trial!
About   Advertise   Forum   Forum Archive   RSS Feeds   Statistics   Tools
