VideoHelp.com Forum
  1. I apologize if this has been already explained in this forum but I can’t find one.
    How can I increase/decrease font size of subtitles? I’m trying to make XVCD with subtitle using Virtual Dub with .ssa file and TMPGEnc.
    Thanks in advance for your help.
    Kang Yul
  2. You can edit the *.ssa file with Notepad and in the line "style" you can find the size. Example "Style: Default, Arial, 14, 253436, 0, 16777215, 0,0,0,2,2,2,20,20,10,0,0". Font Arial and 14 is the size. Its so simple. Other way is to use software to manipulate and convert this files. There are many. See at http://www.divx-digest.com/software/...html#subtitles
  3. Thanks. I'll try.
  1. Replies: 4
    Last Post: 6th Mar 2011, 19:34
  2. Font size will not change size
    By pgwillin in forum ffmpegX bugs and suggestions
    Last Post: 8th Jan 2011, 14:04
  3. Subtitles Font Size Trouble
    By gdm1134 in forum Mac
    Last Post: 11th Aug 2009, 21:57
  4. MKV, subtitles are tiny. How to change font size?
    By anarchyx34 in forum Video Conversion
    Last Post: 14th Apr 2009, 01:17
  5. Subtitles - colour and font size
    By CompVid in forum Software Playing
    Last Post: 18th May 2008, 14:18
