Results 1 to 24 of 24
Thread: DivX vs. XviD
    Sorry for my question and if it has been asked and answered before, but I couldn't find anything.
    The question is, which of the two codecs is better, why, what exactly is the difference, the difference in decoding times, encoding times, file size, quality etc.
    P.S. Sorry for my bad English .
  2. Member mats.hogberg's Avatar
    None.
    The difference is XviD is free, DivX is a proprietary format.
    /Mats
  3. Member Marvingj's Avatar
    DivX 3.x
    Advantages :
    Good compression, even though less advanced compression features are used
    Better compatibility
    Disadvantages :
    DivX 3.x not entirely legal (hacked codec)
    Outdated - does not have advanced compression features of DivX 5.x
    Hard to control final file size
    DivX 5.x
    Advantages :
    Great for controlling final file size (eg. for fitting onto one 700 MB CD)
    More advanced compression features (eg. DivX Pro : multi-pass, bi-directional enc, GMC, Qpel), which may give better compression
    Completely legal solution
    Disadvantages :
    DivX Pro not 100% free (free ad supported version or purchase required)
    XviD 1.x
    Advantages :
    More advanced compression features (eg. 2-pass, bi-directional enc, GMC, Qpel), which may give better compression
    Completely legal and open source solution
    Disadvantages :
    Less common than DivX
    XviD slightly harder (less consumer friendly) to configure than DivX
    http://www.absolutevisionvideo.com
    BLUE SKY, BLACK DEATH!!
    Originally Posted by Marvingj
    XviD 1.x...Completely legal
    Tthis is not exactly true. Xvid likely infringes on several patents. This is why the xvid.org only supplies the source code for "educational purposes." You have to get executables elsewhere.
    For the OP:
    Xvid and Divx are two implementations of the MPEG 4 part 2 (ASP) specification. As has been noted, Divx is a commercial product, Xvid is a "free" open source product.
    In my opinion, when similarly configured, Xvid delivers slightly better quality (for a given file size) but takes longer to compress. Xvid is also more configuration options so it can be better tailored to specific purposes.
    There are no set-top Divx/DVD players that support Xvid's optional 3 warp point GMC.
  5. Member Ansuer's Avatar
    Completely agree. I have about 2 terrabye worth of videos (DVD's, TIVO HD's, etc...) converted to xvid. Though I've since moved on to x264 I would still say XviD gives the best quality when properly configured.
    Of course, it took me many hours of watching conversions until the settings just right.
    Ansuer - "try not... do... or do not... there is no try"
    Can you recommend the settings and tool(s) you use?
  7. Member ntscuser's Avatar
    For what it's worth, there are fewer compatibility issues with DivX on my standalone player than with XviD's but I'm not sure of the reason?
  8. Member Ansuer's Avatar
    Here is an example of how I encode DVD's to XviD
    I primarily use DGIndex to index the video and split the file.
    Then use AVISynth to cleanup and filter the index file like this:
    LoadPlugin("\Convert\Scripts\AVISynth\DGDecode.dll ")
    LoadPlugin("\Convert\Scripts\AVISynth\Decomb.dll")
    LoadPlugin("\Convert\Scripts\AVISynth\degrainmedia n.dll")
    LoadPlugin("\Convert\Scripts\AVISynth\MSharpen.dll ")
    V=mpeg2source("INPUTFILE")
    AssumeTFF(V)
    V=Telecide(V,guide=1,gthresh=5,post=0,vthresh=20,d thresh=5,blend=false)
    V=LanczosResize(V,1024,576,4)
    V=DeGrainMedian(V,limitY=4,limitUV=5,mode=0)
    V=MSharpen(V, threshold=15, strength=100, highq=true, mask=false, debug=false)
    ConvertToRGB32 (V,"PC.709", interlaced=false)
    Open the avs file with virtualdub and use these XviD settings:
    Profile Level: unrestricted
    - Quantization Type: H.263
    - B-VOPs
    - Max consecutive BVOPs: 2
    - Quantizer Radio: 1.50
    - Quantizer offset: 1.00
    - Packed bitstream
    - everything else defaults for profile level
    Encoding Type: single pass (this one's up to you, I use the defaults)
    quantizer: 3.00
    Zone Options (for the entire video)
    - Weight: 1.00
    - Begin with keyframe
    - Chroma optimizer enabled
    - BVOP sensitivity: 5
    Quality preset (user defined)
    - Motion
    - Motion search precision: 5
    - VHQ mode: 1
    - Use VHQ for bframes
    - Use chroma motion
    - Frame drop ratio: 0
    - Maximum I-frame interval: 300
    - Quantizer restrictions
    - All min's set to 2
    - all max's set to 20
    - Trellis quantization
    Other options
    - FourCC Mode: XVID
    Finally:
    Use the built-in temporal smoother filter in virtualdub set to 2
    Also use the DotCrawl Comb filter from Scott Elliot with no temporal filtering and max spacial filtering
    Mux it all back together with virtualdubmod
    That's it!
    I usually use similar Xvid settings. But I set the I-frame interval to 100 for better seeking during playback.
    Target Quantizer mode is a constant quality mode. You set the quality you want and the file comes out to whatever size is needed to achieve that quality. Setting the quantizer to 3 is a good compromise between size and quality -- better quality than most stuff you might download from the internet. Smaller values give better quality but larger files. Higher values give less quality and smaller files. You can enter non-integer values. There's no point in going below 2, the files will get very large and there will be no perceptable increase in quality. The Min/Max quantizers don't matter in Target Quantizer mode. If you want much smaller files you will get better results with 2-pass VBR compression.
    If you need better standalone compatability set Max consecutive BVOPs to 1. For even more compatability, turn off packed bitstream.
  10. Member ATLien's Avatar
    There is now. lol
    There is now. lol
    Maybe you could list the ones you know.
  12. Member FulciLives's Avatar
    Some programs that make DivX / XviD encoding easy:
    1.) XVID4PSP
    2.) autoGK
    3.) avi.NET
    Please note that this list is in no order per se and I have used all three successfully. All three are made in such a way as to a.) make the process easy and b.) make a DivX / XviD that is compatible with stand alone hardware like the DVD players that can play DivX and XviD.
    - John "FulciLives" Coleman
    I used DivX 3.11 for a long time until users here convinced me to use the XviD codec since it had better compression.
    Since the DivX 6.8 codec was released, that's primarily what I use since the compression is comparible to XviD but the encode speeds are much faster. I usually encode in Home Theater mode with a constant quantizer of 2 or if I'm encoding HD DivX then I'll use either 720HD profile or 1080HD profile with quantizer of 2.
    I still use the XviD codec for resolutions that the DivX codec refuses to encode.
  14. Member ATLien's Avatar
    There is now. lol
    I have no problems with the Phillips DVP5992. Plays everything I throw at it...er...except .mkv's. But hell all I wanted was something I could play Xvid & Divx file with doing any re-coding. I can get 6-7 movies on a disc with no problem.
    I use the PS3 for those other files, i.e. .mkv's
    The Philips DVP-5992 does not play Xvid's 3 warp point GMC well. Try this:
    xvidgmc.avi
  16. Member PuzZLeR's Avatar
    Think of it this way.
    MPEG-4 ASP is orange juice, while other video formats MPEG-2, MPEG-4 AVC/H.264, WMV, etc are other types of juice.
    DivX and Xvid are brands of orange juice. Both are made from different entities so they can't be exactly the same thing, but both have more similarities than differences since they're based on the same "fruit".
    The biggest difference is that one is sold (DivX) and the other is given away free (Xvid), so there will be culture differences.
    But which is better in quality? This is all taste. Everyone will have an opinion on this, but most won't find any major advantage to either.
    The best thing is to taste each and determine for yourself which is "better".
    Been away for a while and busy with work the last few months so I had no time for forums. My apologies for any emails I couldn't get to in time - missed you all! :-)
  17. Always Watching guns1inger's Avatar
    /* wait quietly for post that begins
    "I tried to play orange juice in my Philips player, and now it won't play any discs at all. . . . . . "
    end wait */
    Read my blogs here and here. Change England's Libel Laws - Sign Here
  18. Member ATLien's Avatar
    xvidgmc.avi
    Plays great in my player.
    Mind you I burned it on a disc as a data file, so I can place more movies on a single disc.
    xvidgmc.avi
    On mine it starts to play they displays an error message "Video GMC not supported". It continues to play but it's very jerky and only plays for about 8 seconds of the 13 second running time. It's the same from USB and DVD. I'm pretty sure it did the same with the original firmware.
  20. xvidgmc.avi .... This wont even play properly on the WD HD TV.
    Divx is given away too...just not the best version.
    The electronic components of the power part adopted a lot of Rubycons.
  21. Renegade gll99's Avatar
    I'm getting the same exact message and symptoms on my unit using a usb stick. I have upgraded the firmware to one of vb6rocod's. I think it's DVP5990_37_vb6_v2_3_2 which I plan to update again soon to his latest.
    I'm not surprised at the result since this was clearly spelled out by Philips.
    btw) If this video plays without flaw on some Philips dvp5990/92 units it would be interesting to see what date the player was made and what firmware version is being used.
    To the OP:
    If your question was raised in the context of compatibility with stand alone Divx players. The Divx players only guarantee to support their codec because there are features of the xvid codec as seen in the GMC discussion which they do not support and may not plan on doing. The future divx players look like they are heading in the direction of the newer divx 7 and support for the mkv container.
    There's not much to do but then I can't do much anyway.
  22. AGAINST IDLE SIT nwo's Avatar
    So what your saying is that DivXNetworks is infringes on it own patents.
  23. Member
    MPEG LA member patents. Divx is a licensee, presumably.
  24. Member t0nee1's Avatar
    guns1inger wrote,
    I tried to play orange juice in my Philips player, and now it won't play any discs at all...
    Damn! too late..I thought freshly squeezed OJ would make a difference..
    "I typed the word Google into Google. Guess what came up? Everything."
    "What we've got here is failure to communicate"
  1. Replies: 4
    Last Post: 5th Jun 2008, 12:47
  2. Make an unplayable Xvid/Divx video play in a divx standalone Player
    By AllenGorden in forum Newbie / General discussions
    Last Post: 31st Dec 2007, 18:25
  3. DIVX OR XVID TO DIVX OR XVID RATIO PROBLEMS!!!!!!!!!!
    By motoko12 in forum Video Conversion
    Last Post: 7th May 2004, 02:26
  4. Converting DivX to Xvid or DivX to DivX in Virtual Dub
    By OctoChops in forum Video Conversion
    Last Post: 4th Dec 2003, 14:57
  5. Problems encoding XVID files to MPEG, XVID/DIVX codec remain
    By damncoolguy in forum Video Conversion
    Last Post: 29th Jul 2003, 01:12
About   Advertise   Forum   RSS Feeds   Statistics   Tools
