We published following filters & programs after last update:
VirtualDub MSU Cartoon Restore Filter - New filter
http://www.compression.ru/video/cart...e/index_en.htm
- One of the most prominent coding artifacts in highly compressed animated video are the ringing artifacts. Ringing noise preferably manifest itself around edges due to coarse quantization. The filter is designed for quality improvement of compressed cartoons like video by deleting ringing artifacts
- Filter is suitable for video restoration (specialized for cartoons, but simple preset suitable for photorealistic video ringing suppression also).
- AviSynth is also supported.
- This is first release, updates with more advanced filtering methods are coming soon.
AviSynth MSU Frame Rate Conversion Filter - New filter
http://www.compression.ru/video/fram...ex_en_msu.html
- The filter is intended for video frame rate up-conversion and contain fast branch of our FRC research (we have also slow versions designed mainly for hardware implementation)
- This is first release, updates are coming soon.
VirtualDub MSU Noise Estimation Filter - New filter
http://www.compression.ru/video/nois.../index_en.html
- This filter is used to estimate mean noise level in video sequences using 4 implemented methods.
- Filter is suitable for video processing automation.
VirtualDub MSU OldCinema Filter 2.0 - update
http://www.compression.ru/video/old_.../index_en.html
- We updated one of our old popular filters. This filter is intended to achieve an "Old cinema" effect. You can vary color correction algorithm and add various artifacts, so video looks like "chronicle".
- New effects in 2.0:
* Improved vertical scratch generation algorithm
* Added large spots generation algorithm
* Added new color correction algorithms
* Improved spots: black and white, and various sizes
* Added image flicking- AviSynth is also supported.
MSU Video Quality Measurement Tool - update
http://www.compression.ru/video/qual...t_tool_en.html----
- MSU VQMT is a program for video quality measurements (for codec and filters tuning). One of our popular programs, used in many universities, now supported by more than 20 companies.
- Last updates:
* Error at the opening YUV-files fixed
* Set of interface fixes
* New documentation
Also we reach one million of total filters downloads:
http://www.compression.ru/video/video_statistics.htm
Congratulations are welcome!
Enjoy!![]()
With regards
Dmitriy Vatolin
http://www.compression.ru/video/ (News: new metrics and WMP vs JPEG-2000 comparison)
Senior editor of Compression-links.info
Many thanks for your on-going work and commitment. I look forward to playing with these new and/or improved versions.
Great, guys, can't thank you enough for your contributions to our hobby.
I tested FRC on critical material and it gave much worse results than the well-known MVTools (MVFlowFPS function). Why is the latter not even mentioned in comparison tests published by MSU?
Everything for you!Originally Posted by guns1inger
Thanks!Originally Posted by redwudz
We have 2 commercial versions of FRC with higher quality (like this one with fine processing of 3 pixels details and good complex motion processing), but we cannot use them in free filters. Main task of this free filter - high quality without using of proprietary technologies. Now main problem is in high motion areas and in updates of current 0.5 release we plan to fix them.Originally Posted by Alex_anderWith regards
Dmitriy Vatolin
MSU MPEG-4 AVC/H.264 2011 Video Codec Comparison - CALL FOR CODECS
By DmitriyK in forum Latest Video NewsReplies: 1Last Post: 28th Jan 2011, 15:27 -
MSU's cumulative update info
By DmitriyV in forum Latest Video NewsReplies: 4Last Post: 10th Oct 2009, 08:05 -
Can't convert screen capture video (MSU SCLS codec)
By nonsey in forum Video ConversionReplies: 13Last Post: 27th Apr 2008, 04:20 -
Fourth Annual MSU H.264 Video Codecs Comparison
By DmitriyV in forum Latest Video NewsReplies: 0Last Post: 25th Jan 2008, 08:39
