hi
i have asus m2n-sli deluxe mainboard.
there should be somewhere esata port on it but not outside (back) of computer case.
how do you connect my external sata HDD (with esata port) to my PC.
thanks for advice
It's the bottom red one
http://www.asus.com/products.aspx?l1...60&modelmenu=1
the esata ports on motherboards i've worked with were always on connectors that slip into an unoccupied bracket opening and connect to the motherboard with cables.
It does have an external port just where it shows you in the previous post (poisondeathray`s). Have the same board and have an esata drive plugged in.
What may be confusing the OP is that the Esata port does not look the same as a internal Sata port.
Esata is the fastest inexpensive way to a fast full speed external drive running much faster than a USB2 or Firewire external. A SCSI external could be faster, however much more costly.
External HD for video editing (USB 2,3 or eSATA) ?
By sdsumike619 in forum ComputerReplies: 2Last Post: 4th Apr 2012, 15:13 -
Can a Laptop with an Esata port Hook up to an Internal Bluray Writer?
By jbitakis in forum DVD & Blu-ray WritersReplies: 2Last Post: 10th Nov 2011, 20:16 -
This External hdd enclosure only confuses the sata vs eSata issue for me
By gll99 in forum ComputerReplies: 13Last Post: 12th Mar 2009, 21:01 -
Can a pci esata card be both internal and external simultaneously?
By yoda313 in forum ComputerReplies: 9Last Post: 1st Dec 2008, 14:45 -
Firewire VS. eSATA/eSATA II - which would you rather have?
By Cyrax9 in forum Camcorders (DV/HDV/AVCHD)Replies: 2Last Post: 13th May 2007, 09:59
