Hi,
Can anyone tell me how to get the title appear on the PSP when you encode a DVD with nero recode? I have tried others the main other converter I use is the "Xilisoft DVD Ripper Platinum" but that creates very big files on the PSP where as Nero is about half the size and quality is good enough for watching on the small screen.
Nero seems well up for the task but I cannot get the title to appear on the PSP I just get a '-' where the title should be, I have renamed the file in Nero but it seems to make no difference.
Mike
Found this using Google: http://forums.pspcrazy.com/forums/ps...-3-7-beta.html
Looks to be the solution to your problem.Google is your Friend
PSP Test Clip: Need someone with a PSP to test for me!
By FulciLives in forum Portable VideoReplies: 5Last Post: 17th Feb 2009, 20:42 -
My XviD4PSP PSP video conversions are not supported on PSP
By godfist314 in forum Portable VideoReplies: 3Last Post: 18th Aug 2008, 10:59 -
Downgrade your PSP to version 1.5 using your PSP battery
By chrise in forum Newbie / General discussionsReplies: 1Last Post: 20th Dec 2007, 08:27
Statistics
Newest guides
Latest tool updates
New media comments
