  1. Hi everyone !
    I wonder if there is an easy way to convert a dts file to wav stereo .... I don't have dts material , and a stereo file is enough for me ... but how to ... please ??
  2. Member Soopafresh's Avatar
    Jan 2004
    foobar will downmix the dts into 2 track stereo
    Your have to copy this into C:\Program Files\foobar2000\components\
    foo_input_dts.rar
    Then choose the "Convert 5.1 to Stereo Downmixer"
    Then, right click on the DTS file when it is playing in Foobar and convert to WAV
  3. Member yoda313's Avatar
    Jun 2004
    The Animus
    You could also simply use any recording software that records "what u hear". That should record to any file type you need while playing the source material assuming the software supports the destination codec.
  4. many thanx
