I am trying to figure out what is the best VOB demuxer, I mean the demuxer that keeps the quality of the original streams. I tried PGCDemux and VOBEdit, demuxing the same VOB file, wich is 4259 MB.
PGCDemux demuxed it in 3.5 mn and output the elementary streams : video 1635 MB, 2 audios each 187 MB.
VOBEdit demuxed the VOB in 8 mn, and the following sizes : video 3382 MB, audios 392 MB each.
VOBEdit is longer but the size of the output is more or less the same as the size of the input, whereas for PGCDemux it is less than half of it. Does this mean that PGCDemux downgrades the quality of the streams ? Or am I using it the wrong way ?
gabier
You're trying to compare apples and oranges. VobEdit demuxes entire VOBs. PGCDemux demuxes by PGC (using the IFO). My guess is that there's at least one more PGC in that VOB that wasn't demuxed. Check the other IFOs (if any) for more PGCs, or check the drop-down box of the IFO you're using for the presence of additional PGCs. -
Originally Posted by manono
There are 2 IFOs, the VIDEO_TS.IFO, with no PGC, and the VTS_01_0.IFO with 1 PGC. Nothing else in the dropbox of PGCDemux.
It seems to me that if nothing is reprocessed, a demuxed stream, for instance the video stream of my movie, should be the same size in both cases, should'nt it ?
Gabier -
Nevertheless, I probably don't understand how PGCDemux works, for its behaviour looks quite peculiar to me. When I open the IFO, the PGC displayed is : "PGC#01 2:22.45.10". So it knows the time length of the PGC. Then, if I ask for demuxing all the streams and hit "Process!", it starts demuxing, the progress bar goes on until about half way, and then it stops with an info message : "Finished OK". The problem is that it has output only 1:07:57 thus it is not OK at all.
If it has encountered a corruption, as you say, or any reason to stop, it should send an error message, eather to the user or to the log file. It does none of these actions. This is not very pleasant.
Gabier
Issues demuxing VOB w\PGCDemux & VOBEdit
By kpic in forum DVD RippingReplies: 15Last Post: 2nd Oct 2012, 03:39 -
With PgcDemux demuxed subtitles can't be added to mkvmerge
By Julian_evil in forum Newbie / General discussionsReplies: 10Last Post: 9th Sep 2011, 00:19 -
strange timing issues ripping dvd with pgcDemux
By ryoaska1 in forum DVD RippingReplies: 4Last Post: 26th May 2011, 22:22 -
PGCDemux/DGIndex audio delay report -- how to proceed?
By Gew in forum Newbie / General discussionsReplies: 1Last Post: 28th Feb 2011, 03:22 -
DVD Demuxer tool making 0kb .VOB files
By Madvillain in forum DVD RippingReplies: 5Last Post: 6th Jul 2009, 04:11
