How to attach subtitles to mkv file?
THX![]()
Get MKVToolnix and use the MKVMerge utility.
theHTPC.net
Find a cure for cancer by folding proteins! Join the Team 32 Folding@Home project (#3 worldwide!). Check us out here
I did'nt find How to Attach. can you give a direct link?
***I need a guide
i want to attach subtitles (SSA) to MKV and save it as MKV
^Because I have a MKV 1.1 GB and it very high quality. and i want to save this quality and attach subtitles. I have to save it as MKV? i just want to save the very good quality and attach subtitles.
and i convert with "ConvertXtoDVD"
or i can do it just with "mkvmerge GUI"? what i need to select in "MINE type"?
Please? Someone?
I'm afraid that even the native speakers of English might be
finding it's difficult to understand what you're trying to say.
sorry, my english is not good.
I have a very high quality MKV file (1.1 GB).
I want to attach subtitles to this MKV file and keep its very high quality.
I don't know if have to keep it as MKV to keep the quality or i'll have to convert into another format.
But I use ConvertXtoDVD, so i need a format that ConvertXtoDVD support it
Is It understandable?
is it understandable? pleas? someone?
i just tried attach one srt subtitle file to mkv with MKVToolnix. it's OK. i just only rename the srt subtitle file same with mkv file. After that i used MKVerge GUI, aty input click add buton and load both file (srt * mkv files). Click Startmuxing for process. We will get the result with subtitle with resolution like source mkv.
My english very pool. i hope this don't mae you confuse and hope useful for you.
bye
How to attach subtitle to .mkv
By KoRatta in forum SubtitleReplies: 63Last Post: 22nd Jan 2012, 08:50 -
How to attach a (.smi) subtitle to .mkv?
By posthuman in forum SubtitleReplies: 7Last Post: 27th Sep 2011, 17:23 -
How to attach .ass subtitle with a .mkv file
By varun in forum SubtitleReplies: 5Last Post: 3rd Aug 2010, 16:39 -
Attach .ass sub file to .mkv problem!
By Jacks in forum SubtitleReplies: 11Last Post: 22nd Jul 2010, 13:52 -
Burning .mkv file with .ass subtitles to DVD WITH the subtitles
By isfjinfj in forum Authoring (DVD)Replies: 2Last Post: 23rd Jun 2009, 16:28
