I have been researching this problem for 2 days now and still no luck!!
Every time I drag .rm files to the ffmpegx window it freezes up. Also when I try to play the file in Mplayer it only plays the audio, though plays perfectly in the Real Player.
What is wrong?? I am obviously missing an rm video codec even though I have "installed" reallib to library>application support>ffmpegx (copied the folder). I also cannot for the life of me figure out how to install the additional codecs into mplayer, which I have downloaded (libmp3lame-osx-universal-3.97). Mplayer came with a GUI and I cant figure out how to get it so i can type in code (although that probably would just have me staring at the computer for 2 more days trying to figure out what to do with that window). I also have no clue what "/usr/local/lib" is, as I am new to mac, so I can't install it manually (if that is possible).
Can anybody help me convert rm and stop me (almost literally) pulling my hair out?? I don't even mind someone suggesting another free encoder if it works, even though I have heard this is the best one...
Please verify that you installed mplayer and reallib correctly:Originally Posted by neilaja
1/ Mplayer OS GUI is of no benefit to ffmpegX. You'll need the CLI version that can be downloaded from the location as mentioned on the website and in the self-installer window. Download the .zip file, unzip it. From ffmpegX's self-installer window, use the Locate button to point the installer to your unzipped file 'mplayer'. On installing, the mplayer file will be manipulate and copied to its Library location, to make it available to ffmpegX. mplayer doesn't need additional codecs (libmp3lame), except for reallib if you convert real media files.
You can verify if this step is done correctly by dropping a test media file (e.g. XviD AVI) on ffmpegX and pressing the Play button. This should start the CLI mplayer and play the file. Press 'q' to quit.
2/ For Reallib (for Intel Macs) you'll need to download the Binary Codec Package - Mac OS X x86 (originally for MPlayer OS X 1.0rc1 from that site), and use that for the (different!) mplayer that ffmpegX will use. The Binary Codec Package is an installer package file. Run it. You can make it useful for the other mplayer by moving the installed reallib files from "/usr/local/lib" to "/Library/Application Support/ffmpegX". The directory "/usr" is invisible in Mac OS X, so navigate to "/usr/local/lib" by using the Finder's Go menu, selecting "Go to Folder...", then type "/usr/local/lib" and press <enter>. You'll see a folder named "codecs". Move this folder into "/Library/Application Support/ffmpegX" and rename it "reallib".
You can verify if this step is done correctly by dropping a test Real Media file (foo.rm) on ffmpegX and pressing the Play button. This should start the CLI mplayer and play the file. Press 'q' to quit.
Make sure you have the Intel version of the reallib files.Originally Posted by Crimian
Installed ffmpegX but not converting
By bene07 in forum ffmpegX general discussionReplies: 2Last Post: 2nd Dec 2010, 15:42 -
Converting MKV to AVI using ffmpegX
By Vitoarc in forum ffmpegX general discussionReplies: 4Last Post: 13th Aug 2010, 10:51 -
Converting RM using ffmpegX
By cmc2008 in forum ffmpegX general discussionReplies: 43Last Post: 30th Nov 2009, 02:09 -
ffmpegX says it's finished converting, but nothing is produced!
By alexliz in forum ffmpegX general discussionReplies: 3Last Post: 12th Dec 2008, 14:16 -
ffmpegX crash when converting to DVD
By granoli in forum ffmpegX general discussionReplies: 0Last Post: 2nd Jul 2007, 18:39
Statistics
Newest guides
Latest tool updates
New media comments
