VideoHelp.com Forum
    Hello i am trying to obtain rip specs from a vidoe ts. folder.
    i stripped using mac the ripper - i now have a folder full of vobs etc
    i need to get as much info as possible before i upload on the traker.
    i usually get the rip specs with a vlc player - from avi files, but it gives next to nothing for a ts folder.
    should i re strip using a different program - or use some other program to get the specs? it doesnt even tell me the frame rate.
    thanks for your help.
  2. Member edDV's Avatar
    You need to demux the VOB to MPeg2. I'm not sure how you do that on a Mac.
    http://www.kiva.org/about
    hmm. but i want to upload it as a dvdr and keep it as vobs.... lots of people do on my tracker
  4. Explorer Case's Avatar
    ffmpegX (with mplayer) can give you a quick summary with details on a VIDEO_TS folder. (Example)
    Wow.. amazing i just tried it... thanks so so much, i ve been waiting for an answe on another forum for days. cheers case.
    Just as a gentle warning, however, note that the analysis does get fooled from time to time. If the movie has elements with two different frame rates (for example, intro or advert material at TV framerates, followed by the rest of the movie in film framerates), it may tell you that the movie is, say, 29.97fps when it is actually 23.976fps. In my experience, if it says that it is film framerate, that is a reliable determination. However, if it says 29.97fps, there can be room for doubt.
  1. BD Rip worked only once, now can't rip BDs successfully
    By thestrangebrew in forum Blu-ray Ripping
    Last Post: 1st Apr 2012, 08:30
  2. How to rip DVD's: Image File or VIDEO_TS-Folder
    By flashandpan007 in forum DVD Ripping
    Last Post: 9th Feb 2010, 10:08
  3. rip dvd folder and keep both audio channels ???
    By hulinning in forum DVD Ripping
    Last Post: 16th Feb 2009, 11:43
  4. Replies: 8
    Last Post: 13th Jun 2008, 13:01
  5. Replies: 5
    Last Post: 31st May 2008, 14:30
