hi all . i keep getting this error:
After effects error: no such AVI compressor
when trying to import youtube avi files to adobe after effects 7 . I downloaded a few vides from youtube using a program and now i can't use them!! could any one tell me how to over come this problem?Thanks
Youtube doesn't use avi, it uses FLV. If you used a program that downloads and converts the video, it has either screwed up (quite likely) or it has used a codec that does not have a decompresser that After Effects can use. Why on earth you would want to use crappy youtube source in AE is beyond me.
Anyway, you have two choices
1. use MediaInfo or G-Spot to work out what you have converted to, and then find a suitable codec for After Effects you use to read the video
or
2. Convert the videos to something AE can use.
Note : As you will have to re-encode after processing in After Effects, and as every re-encode costs you a quality hit, I would suggest you convert your YouTube flv video to something uncompressed or losslessly compressed (using lagarith or Huffyuv), then process it in After Effects, and either compress from there to your final format, or again to a lossless format until you are finished.
How to export from after effects to youtube? (its just not 'happening')
By Devilsadvocate in forum EditingReplies: 0Last Post: 3rd Mar 2012, 04:14 -
Adobe Premiere Deinterlacing/youtube/HDV quality problem
By qatzo in forum Newbie / General discussionsReplies: 21Last Post: 4th Jun 2011, 13:12 -
Youtube HD videos to lossless .avi files
By snafubaby in forum Video ConversionReplies: 5Last Post: 17th Jul 2010, 21:50 -
Adobe After Effects 7.0 Pro Crashing Problem!
By SciFiGeek17 in forum EditingReplies: 1Last Post: 3rd Jan 2010, 18:01 -
Youtube problem - Exporting from After Effects CS3
By slc2008 in forum Video StreamingReplies: 0Last Post: 12th Aug 2008, 09:22
Statistics
Newest guides
Latest tool updates
New media comments
