  1. Hello,
    I have an Nvidia Geforce 8600 GTS card that I am trying to output video from to an RCA 32" TV, not an HD or anything but an older model. The picture itself is fuzzy and it outputted color to a 13" Sylvania TV though it was fuzzy as well. When I uninstall the driver it outputs in color but then MC won't work. I am using an S-Video to RCA cable to output that is maybe 3 feet long. I have tried this in Vista and XP Media Center that I installed on my computer afterwards. I'm guessing it is either the cable being low quality or the driver that is just not going to work to do this. Frankly, I am at my wits end. I have searched everywhere and found no solution to the issue. So, does anyone have any idea what to try. Here is what I have done so far:
    1. Went throughout the settings in Nvidia control panel and made sure Saturation and any setting that deals with color was put everywhere.
    2. Uninstalled the driver which immediately outputted color but also immediately sucked because the driver installed was Standard VGA. This leads me to think Nvidia drivers don't play nice with outputting to older TVs. Am I correct? If so I am a bit upset...
    3. Formmated and switched to XP Media Center Edition hoping that XP drivers would work. No luck.
    4. Tried running the TV wizard to test in composite, s-video and component with no luck.
    5. Prayed and wept.
    OK, so what have I done wrong? Are there drivers for TVs? Are there better drivers for Nvidia? SOmeone want to give me an HDTV for free?
    Nick
    make sure in the settings you have chosen your correct output NTSC/pal
  3. Member edDV's Avatar
    Did you try another S-Video cable?
  4. Member mats.hogberg's Avatar
    Frankly, I've never succeded in getting anything else but b/w picture from my nVidia card(s) using S-Video. Composite's fine tho.
    /Mats
  5. I have made sure the settings are correct as to NTSC with no luck.
    This is the only cable I have but I did order a better cablw JIC.
    I know of others have better luck with it. I'm kepping my fingers crossed.
    Nick Queen
  6. Originally Posted by nicolasqueen
    Bought a converter between the two cables and it worked. Before I had a single mixed cable.
    Nick Queen
    If it is a cheap cable only two of the wires are in use. Go buy a cheap male to male s-video cable cut one end off and cut the s-video connector off of your cable. Wire the new one in like this , tie pins 3+4 together and tie them to the center yellow video pin wire, then tie pins 1+2 together and tie them to the yellow video ground wire it will show in color. You can see a pin out on wikipedia under s-video.
    Brian Rayburn
  8. Member Noahtuck's Avatar
    It's so easy to spot the truely newbish
    Originally a member since 2001, LONG LIVE TARAN's!!!
  1. Replies: 4
    Last Post: 5th Jan 2009, 02:59
  2. Nvidia 8600 GTS graphics card Insuficient power supply with Antec 500w
    By Hogie in forum Newbie / General discussions
    Last Post: 4th Jan 2009, 22:11
  3. Replies: 19
    Last Post: 19th Nov 2007, 01:05
  4. black and white screen on tv from nvidia mx 4000
    By D34 in forum Software Playing
    Last Post: 19th Oct 2005, 13:55
  5. Leadtek GF2 GTS - TV-Out Black and White
    By Necromancyr in forum Software Playing
    Last Post: 2nd Jul 2001, 07:36
About   Advertise   Forum   RSS Feeds   Statistics   Tools
