I am using DVD Styler to create a simple DVD, but the final source looks to be interlaced. Maybe the term is not correct, but i have a lot of horizontal lines going though my video. Can someone help me out?
Here's the GSpot screenshot of my source files
http://i16.tinypic.com/80nkais.png
Yes, your source is interlaced. It should be burned to DVD as interlaced. If done properly you won't see any interlace comb artifacts when you watch on TV.
can you please elaborate on what you mean by the last part? what do you mean "if done properly"
here are the settings that are used to generate the DVD, maybe i could change something here?
http://i14.tinypic.com/6qcvmhe.png -
It wouldn't have anything to do with the authoring. It would depend on the encoding, more specifically if you did an interlaced resize incorrectly.
I'd suggest burning it to disc and testing it in your standalone. If you have any problems, then maybe a description of the source video and how you did the MPEG-2 encoding, along with a small sample of the output, would help.
Help installing DVD Styler
By Garibaldi in forum LinuxReplies: 10Last Post: 3rd Apr 2012, 19:17 -
DVD styler error
By mikeoliver1313 in forum Authoring (DVD)Replies: 18Last Post: 10th Apr 2011, 05:04 -
DVD Styler Fails to Burn
By mik1 in forum Authoring (DVD)Replies: 1Last Post: 10th Jun 2010, 01:57 -
New dvd styler error.
By mikeoliver1313 in forum Authoring (DVD)Replies: 2Last Post: 21st May 2008, 08:51 -
DVD Styler problem
By bennyboy371 in forum Authoring (DVD)Replies: 1Last Post: 24th Jul 2007, 21:01
