VideoHelp.com Forum
    I have two mkv movie files and tried to convert them to AVI files in order to burn DVD, I tried several kind of mkv converter’s trial version but failed. The symptom was when I added my file to convert, it dead or just doesn’t work. I don’t know why and hope if someone can recommend a good one which has free trial version.
    or give me some advices.
    Thanks!
    Do you want a dvd-video? then try convertxtodvd or favc.
    Do you want an avi on a dvd disc? then try alltoavi.
    .Do you want an avi on a dvd disc? then try...
    If you mean I convert my mkv file to a AVI file then burn a DVD disc?
    Thanks!
  4. Member Krispy Kritter's Avatar
    Thanks!
    What does that mean????
    What Baldrick was asking is what final format are you wanting?
    You can convert the mkv to mpg2 and create a disc that meets the DVD spec or you can just convert the mkv to avi. Both tools are listed above.
    Google is your Friend
  5. Always Watching guns1inger's Avatar
    You could try SUPER.
    Personally, I would use DVD Flick or FAVC, then VOB2MPG. It's two steps, but the quality will be much higher than SUPER will produce.
    Read my blogs here and here. Change England's Libel Laws - Sign Here
  1. Replies: 8
    Last Post: 29th Oct 2011, 19:35
  2. Replies: 3
    Last Post: 19th Feb 2011, 17:38
  3. Convert MKV to AVI/MPEG-2 High Quality file for HD author
    By ronorkis in forum Video Conversion
    Last Post: 1st Nov 2010, 08:23
  4. Failed attempts at hardsubbing .srt file to .mkv
    By wyrewolf in forum ffmpegX general discussion
    Last Post: 17th Apr 2010, 03:53
  5. Help to convert high definition MKV video to DVD-Player compatible AVI file
    By lovecraft123 in forum Newbie / General discussions
    Last Post: 1st Mar 2008, 18:22
