VideoHelp.com Forum
    HI, I bought my Sony RDR-HX725 DVD recorder in Germany and now moved to the USA. Is there a way to change something in the DVD recorder to make it work on NTSC TV Program? It is code free, so I can watch DVD´s from the US, but for some reason it plays the gernan DVD´s that I have in a grey and bad picture with no sound and it is not able to record any program from the US TV Program. I was hopeing to be able to switch it somehwo to change it so that it would record US TV and so that it would play both german and US DVD`s.
    Can anybody help me on that! Please respond.
    Thank you a lot!
  2. Member Krispy Kritter's Avatar
    You should refer to the user manual. In order to record NTSC TV stations, it will need to have a NTSC tuner. If it does, then there will likely be a menu option to change. However, I doubt that is the case. It would be a mostly pointless option and raise the cost. That is why most players/recorders are regional.
    Google is your Friend
    Thank you for your responce. Unfortunatly my DVD recorder does not have a NTSC Tuner. So I believe there won´t be a chance to make it work!?
  4. Member Krispy Kritter's Avatar
    It may or may not still function for recording from the video input (Line In), it just can't tune and record TV stations.
  1. Sony RDR-HX725 Hard drive replacement
    By Towbar in forum DVD & Blu-ray Players
    Last Post: 12th Dec 2010, 02:16
  2. Sony RDR-GX7
    By joecass in forum Newbie / General discussions
    Last Post: 16th Dec 2009, 18:53
  3. Sony RDR-RXD890
    By dixons in forum DVD & Blu-ray Recorders
    Last Post: 12th Mar 2009, 23:37
  4. Is Sony RDR-HX720 compatible with Sony HT-SS2300
    By abdul_sma in forum DVD & Blu-ray Recorders
    Last Post: 6th Nov 2008, 09:14
  5. Sony RDR VX410
    By wozmac in forum DVD & Blu-ray Recorders
    Last Post: 21st Sep 2007, 11:57
