I'm looking for a Dvix/Xvid compatible DVD player with USB which supports an NTFS hard drive. All I've found so far is FAT32 compatibility. Doesn't anybody make a model which keeps up with today's technology? FAT32 is so 90's. If not a DVD player perhaps a different suggestion. If I had was in charge of R&D I'd have one with CAT5, wifi lan, and USB2.0+NTFS support. Am I missing something somewhere?
What I'm wanting to do is use my external 500GB HD to play video files directly without having to burn DVDR's. I know there are a handful of DVD players I can get using USB+flash drives, but I'd rather take it a step farther if I'm going to buy a new unit.
thanks in advance.
Thread: DVD player w/USB NTFS format?
usaRaydar wrote:
Perhaps these quotations from Wikipedia might explain something:All I've found so far is FAT32 compatibility. Doesn't anybody make a model which keeps up with today's technology? FAT32 is so 90's.
The exact specification is a trade secret, although (since NTFS v3.00) it can be licensed commercially from Microsoft through their Intellectual Property Licensing program.NTFS has five versions:
* v1.0
* v1.1
* v1.2 found in NT 3.51 and NT 4
* v3.0 found in Windows 2000
* v3.1 found in Windows XP, Windows Server 2003, and Windows Vista
These final three versions are sometimes referred to as v5.0, v5.1, and v6.0, after the version of Windows NT with which they ship. Each newer version added extra features, for example Windows 2000 introduced quotas while Windows Vista introduced Transactional NTFS, NTFS symbolic links, and self-healing functionality.[7]
Details on the implementation's internals are closed, so third-party vendors have a difficult time providing tools to handle NTFS.
That about sums it up. Especially when most people looking for a Divx player, want a cheap Divx player.
Google is your Friend -
And there are some strong implications that Microsoft's licensing terms for NTFS are expensive, given that Apple has read only support for the file system and so many DVD player manufacturers seem to only support FAT32. If not cost, it may be that Microsoft doesn't really want people outside of Microsoft using NTFS because they have some typical irrational Microsoft fear that the more people that know about Microsoft's secret stuff, the worse it will somehow be for Microsoft. They seem to prefer this odd situation we have now where people have reverse engineered support for NTFS and paid Microsoft nothing as a result. Anyway, I've never heard of DVD players supporting anything but FAT32 and that doesn't seem likely to change.
If that's what you want to do, why bother with dvd players at all? You never heard of the new PopcornHour? Or last year's Tvix4100/Tomacro Limhd. Or the even older Mediagate 350 and 35.Originally Posted by usaRaydar
Better yet (assuming you're playing only SD files since you're talking about dvd players), put your 500gB hd into an NAS in a closet in the basement, and stream your videos thro' an xbox running XBMC inyour room. For SD content, XBMC is the best media center there is currently.
Best software to re-format NTFS 2TB HDD to FAT32?
By jbitakis in forum ComputerReplies: 26Last Post: 29th Dec 2012, 16:59 -
Philips BDP2700 plays MKV files and can use a USB NTFS formatted drive
By Big Bob in forum DVD & Blu-ray PlayersReplies: 19Last Post: 22nd Dec 2012, 21:07 -
Hulu, Netflix, NTFS USB BluRay Player
By sbman2010 in forum DVD & Blu-ray PlayersReplies: 4Last Post: 28th Feb 2011, 11:08 -
Question how to copy ntfs file onto USB memory stick (not in Windows)
By jimdagys in forum ComputerReplies: 10Last Post: 18th Oct 2008, 10:13 -
USB HD - EX2 or NTFS support with large file
By Robcio in forum DVD & Blu-ray PlayersReplies: 5Last Post: 5th Feb 2008, 10:23
