I followed the TVersity guide on afterdawn to stream videos to my xbox360.
http://www.afterdawn.com/guides/arch...0_tversity.cfm
I downloaded an mp4 video clip from google and it worked great.
When I tried a 23min avi file It does work except 2 things:
1) the video freezes every now and again which I attribute to my 800mhz amd athlon cpu being at 100% when trying to stream.
2) the video is displaying upside down AND mirrored (the left and right is switched)
Has anyone ever heard of such a thing? If so what can I do to fix this?
I would appreciate any help!
Thread: TVersity
1) Some videos are transcoded/converted in realtime to wmv because the xbox 360 only supports wmv and some mp4. Try reduce the video resolution under the Settings->Transcoder and see if it helps. But if you just have a 800mhz athlon cpu I don't think it will help.
2) Probably some codec problem. Have you installed any codec packs? I just have ffdshow and ac3filter and it works fine together with tversity.
I have ffdshow, maybe I will uninstall and reinstall the latetest version.
Is there like true uninstall tool that will rid my registry of everything ffdshow. or is the uninstall.exe good enough
Other people have reported the same inversion/mirror behaviour with TVersity and the XBox360 due to a problem with the latest versions of ffdshow.
Check this out (Go to the bottom) :
http://forums.tversity.com/viewtopic.php?t=4522
TVersity Media Server - Cannot Access Folder
By wahla21 in forum Video StreamingReplies: 5Last Post: 22nd Nov 2009, 16:21 -
Streaming with TVersity and AC3 audio
By Igniss in forum Video StreamingReplies: 4Last Post: 23rd Oct 2009, 16:52 -
stream HD movie from Pc to Xbox using Tversity - help
By loki1664 in forum Media Center PC / MediaCentersReplies: 2Last Post: 9th Jun 2009, 14:49 -
PS3 + TVersity Photo Display?
By Browncoat in forum Media Center PC / MediaCentersReplies: 3Last Post: 4th Jan 2009, 13:06 -
TVersity to PS3 - Cannot see media server
By guns1inger in forum Media Center PC / MediaCentersReplies: 2Last Post: 26th Dec 2008, 23:20
Statistics
Newest guides
Latest tool updates
New media comments
