Hi, there!
I am looking for a small portable TV (color or b&w) that can handle both NTSC and PAL input signals from video sources. Better yet, a color NTSC-only portable TV that can handle PAL in b&w is also acceptable (I have heard that some models can do that). I want to use this TV for testing purposes with different video equipment in different places, so the small footprint is important for me.
C Albert L
discomakberto
Results 1 to 13 of 13
Thread: Portable NTSC & PAL TV?
There are a few companies that carry multi format TVs but they may not be that small, mostly 15" LCDs
http://www.220-electronics.com/
http://www.world-import.com/tv.htm
Or try a search for ' multi format TVs '.
I think you are misunderstanding how this works. All NTSC TVs that don't support PAL show PAL in black and white. The problem is that the image scrolls constantly and is thus unwatchable. I've never heard of any NTSC TVs that are able to display a PAL image correctly in black and white. Either you have a multistandard TV which supports both formats or you have an NTSC TV that is incapable of displaying a watchable PAL image. There is no middle ground.Originally Posted by Disco Makberto
Hello, Redwudz!
Thanks for your links.
The problem with the TV's that those vendors sell, as you correctly pointed out, is that they are not truly portable, though I still hope to find one.
CAL
P.S.: I am looking for something like 5", 7", or maybe 9" inches.
Hey, Jman98!
Some old TV's, those that have the button to manage scrolling, for instance, can show PAL videos in b&w. But you are right, there are other considerations that makes watching less than perfect; stretching could be an issue, for example. But in my case, those are minor issues since I would like the mini TV for testing purposes, not for watching purposes.
Cheers,
CAL
You could try looking around the internet for a small (Maybe 7" screen.) portable player. But all the ones that are multi-format I saw seemed to be for DVD playback and didn't seem to have any video/audio inputs. But there may be one out there.
Thank you, Redwudz!
I found one similar to the one you are mentioning. It was a traditional CRT, NTSC & PAL, with DVD playback and A/V inpputs (and FM/TV tuners too). However, I think it is too expensive at more that $200.00. I was hoping to find someting less than $50.00...
I'll keep trying, and I will report back if I find something.
CAL
P.S.: I forgot. The portable TV had a 5.6" screen. Thanks!
Update:
I found some cheap portable NTSC TV's with V-Hold control (for the scrolling issue), and A/V inputs. It could very well be the case that one of these portable TV's handle PAL signals, at least up to an acceptable point. I am going to buy one of these and test it with my NTSC & PAL VHS player, and I will report back in about two weeks. I hope to be sucessful.
Carlos Albert L
Go on ebay.co.uk and get a PAL LCD TV and/or monitor. Virtually all will accept either a PAL or NTSC signal and display it properly.
How about this http://cgi.ebay.co.uk/Slim-7-LCD-TV-...QQcmdZViewItem
I forget that on your 'side of the pond' dual PAL/NTSC TVs are common.
Good idea about E-Bay.
It's too bad US TV manufacturers didn't adopt the same setup.
I would love to get a portable TV-like monitor like those models that are used for security purposes. Basically all of them, even those for sale here in the US, are NTSC and PAL. Of course, a TV-like monitor doesn't have a TV tuner, but I don't need a TV tuner. The challenge is to find a cheap one.
C Albert L
D-Mak
Apparently, there are some NTSC-only TV-like monitors, but still, NTSC and PAL TV-like monitors are easy to find in the United States. The point that I am trying to make is that this is unlike TV with tuners that are hard to find with both NTSC and PAL systems in the United States. I have no idea why this is the case, but I can tell you this has been my experience so far.
C Albert L
D-Mak
http://www.bestbuy.com/site/olspage....=1142290252289
I have one and it plays multi region PAL DVD's with a hack and has an input.
DVD players that play PAL & NTSC - do you need a PAL television?
By ibzomie in forum Newbie / General discussionsReplies: 9Last Post: 12th Dec 2010, 20:53 -
Portable DVD player. Region free. Pal/NTSC
By jtrinc in forum Portable VideoReplies: 2Last Post: 16th Aug 2010, 09:28 -
PAL & NTSC in the same camcorder
By griffmedia in forum Camcorders (DV/HDV/AVCHD)Replies: 5Last Post: 24th Feb 2009, 11:55 -
Portable Dvd Players...PAL/NTSC Friendly?
By Moontrash in forum DVD & Blu-ray PlayersReplies: 3Last Post: 25th Dec 2008, 18:41 -
Viewing quality between PAL & NTSC ??
By VEBouto in forum Newbie / General discussionsReplies: 24Last Post: 22nd Oct 2007, 12:50
