Hi - sorry if this has been asked before, I've had a look around the site and couldn't get an answer. I've been looking at hd-dvds on playusa.com and they are marked as Region 1 only. But I was sure that I had read that all HD discs so far are region free? If this isn't true, does anyone know if the XBox 360 drive (that I am running through my pc) is multi region or region-hackable?
thanks
frank
well this is not really the site you want. To find all of the answers you are looking for, check out the forums and guides over at
www.xbox-scene.com
You are correct, HD-DVD's are currently region free.
Google is your Friend
HD-DVDs are region free deliberately to help the format (potentially) defeat BluRay. Toshiba execs are very fond of saying that HD-DVDs you buy anywhere in the world will work anywhere in the world.
how do you record xbox 360 gameplay while using microsofts xbox 360 vga ?
By rushinplaya in forum CapturingReplies: 18Last Post: 3rd Apr 2010, 06:19 -
XBOX 360 HD DVD drive on Asrock ION 330 - 1080p playback
By dhomas in forum Software PlayingReplies: 2Last Post: 3rd Jan 2010, 21:20 -
Can you interchange a xbox 360 hddvd drive between pc and 360?
By yoda313 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 23rd Oct 2007, 09:06
Statistics
Newest guides
Latest tool updates
New media comments
