VideoHelp.com Forum
Results 1 to 10 of 10
    I tried posting in the bugs forum, but I wasn't really getting an answer...
    When I tried installing ffmpegX onto Leopard, I downloaded the necessary files, pasted them on my desktop, but when I tried to install, I got an error saying:
    ##sh: -c: line 0: unexpected EOF while looking for matching `''
    sh: -c: line 1: syntax error: unexpected end of file
    Am I doing something wrong?
    Thanks for your help!
    There are two common sources of this problem:
    1) Pathname contains special characters (such as spaces).
    2) Your admin pw contains special characters.
    Stick to plain old alphanumerics for minimum trouble...
  3. I had this too (think that was the error anyway) - was because I'd not had a user password set up, did that and it was fine
    This is the error trying to install mencoder, mplayer binaries, mpeg2enc on my MacBook iCD 2.0Ghz 13" White with Mac OS X 10.5
    WARNING: Improper use of the sudo command could lead to data loss
    or the deletion of important system files. Please double-check your
    typing when using sudo. Type "man sudo" for more information.
    To proceed, enter your password, or type Ctrl-C to abort.
    Password:
    anyone kwow the solution?
  5. Did you actually enter your correct OSX login password?
    Password:
    I had exactly the same error message ... I tried 10 times ... no success ...
    I had exactly the same message as the above post (WARNING: Improper use of the SUDO...). I tried putting the binaries on the desktop as suggested in another posting, but got the same result. Then I remembered a similar problem I had a couple of years ago with another program. The solution was to add a password to my user account (I was not using a password), run the install, then remove the password. This was successful, everything installed normally.
    I just changed my password to a one word code. It wasn't hard, and also, make sure you enter your password into the bar on the bottom before you click the install button or whatever it is.
    Password:
    I got the same error as well. I don't use an OSX password so I leave it blank and click "install". I didn't get this error running Tiger so I tried adding a user password in OSX and this fixed the problem. Is there an update so that I can remove my OSX user password?
    Just go back into accounts and change your password again, but leave "New Password" and "Verify" blank this time.
  1. Unable to install ffmpeg in Mac G5 MacOS Leopard
    By oicram in forum ffmpegX general discussion
    Last Post: 8th Aug 2010, 09:17
  2. trouble finding install files snow leopard 10.6.2
    By bookerfatz in forum ffmpegX general discussion
    Last Post: 2nd Feb 2010, 16:52
  3. Installation Error In Leopard
    By Lefty! in forum ffmpegX bugs and suggestions
    Last Post: 6th Dec 2008, 04:14
  4. Applescript error in Leopard build 9A527
    By rbrakes in forum ffmpegX bugs and suggestions
    Last Post: 17th Dec 2007, 12:18
  5. Replies: 6
    Last Post: 12th Dec 2007, 10:13
