VideoHelp.com Forum
    Region free (codes) for Durabrand DPV - 709 ????
    Can anybody help me to make my Durabrand DPV 709 work with any region (free region ) ?? ( codes )
    Thank you very much !!
  3. Banned
    Don't you mean Durabrand PDV709 ?????
    http://www.videohelp.com/dvdhacks/durabrand-pdv709/7787
    YES, but that code 9735 from both users doesn't work...i need try some thing else....
    Hi All
    Does anyone have an updated code for the 2007 Durabrand PDV709 portable DVD player?
    I bought one in the last month or so and I also cannot unlock the region - I have tried everything from 9735 to 359735 to 2379 plus a set of other codes for other Durabrand models by direct entry after the cover is opened and also pressing the stop button right after the cover is opened but before the code is entered.
    I would appreciate any info in this regard.
    Alex
    OK - after much searching I found a new code that works with these newer machines - 9753 - just switch the power on and open the DVD cover - then use the remote and enter the code 9753 and this will open the reional setup screen. There you can choose 0 for all regions.
    Alex
  1. Durabrand PDV-705. Please Help.
    By sandroace in forum DVD & Blu-ray Players
    Last Post: 16th Sep 2011, 03:09
  2. Reds look wrong for Rec.709
    By Jeff B in forum Newbie / General discussions
    Last Post: 23rd Apr 2011, 18:14
  3. Durabrand DVD-2005 - Subtitles
    By cyrill666 in forum DVD & Blu-ray Players
    Last Post: 23rd Jan 2011, 01:56
  4. Philips DPV-5992 not recognizing a USB HD - "Input Invalid"
    By benvid in forum Newbie / General discussions
    Last Post: 21st Jun 2008, 17:02
  5. Durabrand PDV-709 (Portable DVD Player) Hack Code needed
    By Caribsurfer in forum DVD & Blu-ray Players
    Last Post: 23rd Dec 2007, 09:49
