VideoHelp.com Forum
    Hello everyone! Firstly, thanks to any and all help. My problem is a weird one. I convert my movies and TV shows successfully, and they play the first one or two times, but then afterwards I try to play them again and Quicktime gives me an error: "Invalid public atom found." To my knowledge I didn't change anything, and I have no idea what could be causing this. I'm going from AVI to iPod. Thanks!
    If a particular file once played successfully, but doesn't any longer, here are some possibilities:
    1) You updated some software, but only incompletely. The "public movie atom" error message usually means it can't locate the correct codec.
    2) You have a disk problem. Run a disk utility to make sure.
    3) Try repairing permissions. Sometimes (particularlly after an OS install or update), permissions get set wrong, and this can cause your problem.
    IF you have the files saved on an external drive (or even if they were at ANY point saved on an external drive), go to your manuf's website and download the latest firmware upgrade for that external drive. Worked for me and solved ALL my .dmg issues, ALL my public movie atom issues, and all my "Error 4960" issues.
    If the files became "corrupt" at some point (while they were on an external drive) - copying them to another location would only be making copies of broken files. You have to go back to the drive (hopefully they are still there). Keeping the files ON the drive, update the firmware. Everything came back for me, instantly. Whew!
    mannox@gmail.com
    Uh, thanks. But given that the OP asked for help almost 2 years ago, presumably his problem is solved by now.
    But your tip may help someone else. Basically, if the file resides on a non-Mac-formatted drive, the "bad public atom" message can arise. Simply copying the file over to a Mac-formatted drive will often fix it altogether. No firmware upgrade necessary in those cases.
  1. Replies: 4
    Last Post: 26th Jan 2012, 17:51
  2. MP4Box : How to fragment a MP4 video to have mfra atom
    By debatkol in forum Video Conversion
    Last Post: 10th Aug 2010, 07:21
  3. Bad/Invalid public movie atom - HD-DVD --> MP4
    By dacookster in forum Video Conversion
    Last Post: 22nd Apr 2009, 09:10
  4. barebone with atom 330 4 1080p
    By Xeo84 in forum Media Center PC / MediaCenters
    Last Post: 6th Jan 2009, 14:37
  5. .MOV home movies - some not working. Invalid public movie atom. Corrupted?
    By marcate in forum Newbie / General discussions
    Last Post: 22nd Sep 2008, 23:18
