I am trying to put a movie from a movie camera, a slide show of stills done with MS Photo Story 3 and a folder with going on to 150 .jpg files. Using EZ Media Creator v10 I finally got the two movies on a DVD but I have been
unsuccessful in putting the data files on the same disk. Is it possible to do this and if so, how?
...>>Sam
Results 1 to 10 of 10
I usually make a separate directory called data, or photos or the like.
"Art is making something out of nothing and selling it." - Frank Zappa -
Hi Folks, Thanks for the pointers.
I am now trying to work with ImgBurn and I am not sure how to do what I want to do. I want to take
a movie clip off of one DVD, a slide show off of another DVD and a bunch of .JPG files in directories and subdirectories and burn them to one DVD. The problem that I am having is how to input the information in to ImgBurn. Can I not just mark the directories and input them? It seems to force me to go down each tree and mark and open at the file level. What am I not understanding?
Am I correct in assuming that you add all of the files you want and then create the image for burning? Or do
you add each set of files, do an image and somehow combine the three images?
Lastly, I do not understand what the top bar in the source area does. I seem to be unable to use it when I
use the Browse for Folder icon. As I said before, when I browse for a folder, I seem to not be able to mark a top level folder, only at the file level within the folders, going down level by level and marking and opening the various files in the subfolders.
Can someone help me out, spin me around and head me in the correct direction?
Thanks much,
...>>Sam -
What device do you want the result to play on? computer or dvd Player ? or xbox355? or both?
Create a JACKET_P folder - that's what Hollywood does (as do I)
;/ l ,[____], Its a Jeep thing,
l---L---o||||||o- you wouldn't understand.
(.)_) (.)_)-----)_) "Only In A Jeep" -
You only need a jacket_p if you are using jacket_p images. You can create any folder you like at the root level. As long as you leave the video_ts and audio_ts (if present) alone, you can do anything. You can put files in the root of the disc so you can install software, if that is your fancy.
For neatness, it is best to create a couple of folders at the root level, and put the files in those.Read my blog here.
Gunslinger, Ok, I got how to mark a folder. I was using the mark file icon and missed the second icon that was to mark a folder. Easy once you know how.
RabidDog, I would like the disk to play on a DVD player but it sure would be nice if it would play on a computer as well.
Classfour, I have no idea what a jacket_p is nor what its significance is. Can you explain a bit more?
Gunslinger, I understand about the Video_ts and Audio_ts but what happens when you have two from different medias and they are the same names? Also, I now understand how to put various files with their directories and subdirectories in the build.
Sorry to be such a newbie but have never ventured into this realm before
and have a lot to learn. Thanks for helping me out.
...>>Sam -
You can't just combine two different sets of VOBs from different DVDs. You can combine them through authoring - DVD Shrink is a simple method if you don't need menus, GUIForDVDAuthor is a free tool if you need to create your own menus, and DVD Remake Pro is the only sane solution if you want to keep both original menus. But you can only have one video_ts folder per DVD.
Read my blog here.
Software and data files vs. playing movies - special dvd player?
By Haopengyou in forum Media Center PC / MediaCentersReplies: 3Last Post: 18th Mar 2012, 06:55 -
Playing AVI Movies as data files with menus
By shans in forum Authoring (DVD)Replies: 25Last Post: 10th Mar 2011, 09:43 -
How to put a lot of movies into single DVD
By TheEmperor in forum Authoring (DVD)Replies: 9Last Post: 19th Sep 2009, 11:48 -
want to put home movies onto dvd
By shashgo in forum Newbie / General discussionsReplies: 2Last Post: 30th Apr 2009, 09:14 -
How many Divx movies should I put on one DVD+R?
By Hank Kinsley in forum Newbie / General discussionsReplies: 11Last Post: 17th Aug 2007, 03:39
