How to convert a DVD to IpoD MP4 with permanent / burntin subtitles.
Tools required:
Fairuse Wizard ($20) from http://fairusewizard.com ( You need the full version and it wont work with the free version from http://mirror.brokenlogic.net/fu2.6-setup.exe either )
AnyDVD($30) or DVDDecrypter(free)
Preparation
If you want to convert from a commercial dvd you must either use AnyDVD and just run it in the background. Or use DVDDecrypter to rip the full DVD to one iso file but it may not work with newer DVDs.
Guide
Type a name for the project and choose a folder, you need a lot hd space.
Select iPod Video under the "Encoding speed" dropdown.
Hit Next
Select your DVD Drive or open the iso file if you use DVD Decrypter
Choose the main movie
Hit Next
Select the main movie title
Hit Next
Select the subtitle stream to include
Hit Next
Select Auto Detect
Hit next
Adjust video resolution, you can just leave it to the default
Nit Next
Waaaaaaaait
Done
Results 1 to 1 of 1
Converting from Flash .flv format to iPod Compatible .mp4 format in ffmpegX
By bananasontoast in forum ffmpegX general discussionReplies: 1Last Post: 3rd Jan 2009, 09:15 -
Fairuse Wizard 7hrs to rip and index from DVD????
By siratfus in forum DVD RippingReplies: 6Last Post: 14th Aug 2008, 14:44 -
DVD to iPod with subtitles burned into mp4 format
By Sydas in forum SubtitleReplies: 3Last Post: 7th Nov 2007, 18:52 -
Fairuse Wizard 2.5 Dvd to Xvid Tv shows help?
By sere83 in forum Video ConversionReplies: 0Last Post: 6th Apr 2007, 19:57 -
Problem w/ ISO (Fairuse Wizard/DVD Decryptor/MagicISO)
By mike202513x in forum Video ConversionReplies: 3Last Post: 16th Dec 2006, 13:25
