I am experiencing a problem with DVDFab Platinum Version 4.0.0.5. With one particular DVD I'm trying to backup, DVDFab finishes analyzing the DVD, and starts the copy process. About one minute into the copy, I receive a "Crash Report" with the following info:
"DVDFab Platinum has encountered a problem and needs to close. We are sorry for the inconvenience."
Was wondering if anyone has experienced this issue? I have sent several copies of the dump to DVDFab's tech support, but haven't received an answer in the past three days.
Results 1 to 10 of 10
Thread: DVDFab Platinum
bigdogdadog
Does it work if you use the latest stable version of dvdfab? not the beta 4.0.0.5.
I had troubles with analyze, it would get ~40% and flag an error. Reloaded 4.0 and disk copied fine.
Reloaded 4.0?
3.2.1.0 This will teach me to reply.
In response to questions, the problem started with the "stable" version, which I assume you are referring to Version 3.2.1. That's when I downloaded the beta to see how it would handle the issue...got the same results. I don't know what's going on with this particular DVD, but I have sent several "dumps" to the tech support address. The software has handled all other backups without a hitch.
bigdogdadog
Go to Common Settings->Read and set it to ignore read errors.
If that doesn't help then check the disc for scratches.
Thanks for the advice, Moviegeek, but am still getting the failure message. At this point, I have to believe that there is a problem with the DVD itself.
Is there a procedure that can be used to alleviate the impact of scratches? I clean DVD's before I work with them, but is there something that can be used to mitigate scratches?bigdogdadog
I do a visual test first,if there are fingerprints I use alcohol to get rid of them.If there are scratches then I use Novus cleaner but some prefer Plexus.
Thanks for the advice Moviegeek...also printed your guide for future reference.
bigdogdadog
DVDFab 5, Platinum Question
By Ric2L in forum DVD RippingReplies: 3Last Post: 18th Jan 2009, 17:19 -
DVDfab Platinum
By jason in forum Newbie / General discussionsReplies: 0Last Post: 8th Mar 2008, 11:05 -
Question on DVDFAB PLATINUM 4
By JRSWIFEY2004 in forum Newbie / General discussionsReplies: 4Last Post: 10th Jan 2008, 20:43 -
DVDfab Platinum question.
By AlecWest in forum Authoring (DVD)Replies: 5Last Post: 30th Dec 2007, 18:46 -
Nero Recode 2 vs DVDFab Platinum
By eon_designs in forum DVD RippingReplies: 8Last Post: 14th May 2007, 10:58
