Pproject: Harvest some exceptionally clean "Future Boy Conan" PAL rips off eMule, throw away the Russian dub first track, edit in some English subtitles, and give 'em to my nephews.
Problem #1: The Eng subs are stripped from a fan-release in which two episodes (crappy quality, or I'd just keep them) were joined into one CD-length file. I'm clueless on how to edit subtitle files to yank every second episode down to the correct time after wiping the first half of the text. (I *ass*ume this is not difficult, and just need a pointer to the right editors.)
Problem #2: The Eng subs start with the happy Conan & Lana singing & running second intro, not the depressing "Earth blows up" first intro (many encoders clip this first intro).
...Ideal solution: Clip "Earth blows up" (which I dislike anyway); mux in subtitles.
Problem #3: I cannot get any of my oodles of muxers to properly open and edit the AVC1/AC3 combo. (Ideally I'd like to do both simultaneously, preferably at an existing video key frame between first and second intros, and stream-copy.)
Problem #4 (purely optional): Cram 'em into AVI (or whatever other container works) so the brats can SAP.
Problem #5 (purely optional, and yes, I am wearing my tasseled dunce-cap for this question): Is there any way to get soft-subs to "force play" either SAP or in VLC/WMP/etc?
Tools I presently have installed (probably forgetting several):
VDub/Mod/Mpeg2 ....many versions
MKVmergeGUI
MKVextractGUI
AutoMKV090
AVI-MUX-GUI
TrueVideoConverter
SuperVideoConverter
Avidemux 2.4 GTK+
MPEG4Modifier
AVIsplit
Yamb
Results 1 to 1 of 1
AAC 2.0 vs AC3 5.1 for h264 video inside MKV container
By ekred in forum AudioReplies: 9Last Post: 26th Oct 2011, 12:36 -
Converting an 1080p MKV (AVC1 H264 with DTS audio) to an AVI
By cpaqf1 in forum Video ConversionReplies: 5Last Post: 22nd Jun 2010, 21:50 -
Merging MPEG2 stream with its AC3 audio... or converting MKV to MPEG2
By cwt in forum Video ConversionReplies: 2Last Post: 5th May 2010, 14:18 -
virtualdubmod will not work with mkv file containing avc1 codec
By impmon2 in forum Video ConversionReplies: 5Last Post: 5th Nov 2009, 11:48 -
How to rip Direct Stream Copies from one PGC. Details inside!
By xlBlOODlx in forum DVD RippingReplies: 2Last Post: 13th Oct 2008, 21:21
