I'm going to start riding the bus next week. Yes it's almost two additional hours doing so (one hour extra each way), but the gas savings will be tremendous.
I have a Nokia N800, and am thinking that would be useful for playing my anime and captured TV shows. But I can't seem to find anything (yes, I have googled) that says what is the best format to convert to for playback on an N800. Am also trying to see how much I can fit into the two gig card I have for it, so compression with decent quality is "better" than full quality![]()
Anyone out there doing this who has some recommendations?
Thanks in advance!
Thread: Best format for a Nokia N800?
What format does it support? If h264 video then use it!
Well, the format thing is the problem I'm having. It states that it supports AVI (but not which codecs), 3GP, and MPEG-1. I know I don't want MPEG-1, and 3GP I suspect isn't much better. So I suspect AVI is the container of choice - but again, WHICH CODEC will it use? Most of the stuff I've been able to find is folks saying that it doesn't deal well with DIVX. I did find a tool called MediaConverter that was designed for the precursor to the N800 (the 770), but the files it produces only work on the N800 if I allow it to clip the frame - which is kind of bad when you're watching stuff with subtitles
Hopefully someone on here has an 800 or at least know what will work!
i think you can install some software to your N800, then it can support different video format as pc.
Nokia N900
By SE14man in forum Newbie / General discussionsReplies: 0Last Post: 15th Jul 2011, 05:25 -
Video Converter For Nokia N8
By skorpinok in forum Video ConversionReplies: 1Last Post: 4th Jun 2011, 08:32 -
Converter for Nokia 5800XM
By Argonisius in forum Video ConversionReplies: 2Last Post: 14th Jan 2010, 00:56 -
Best FORMAT for PLAYBACK on NOKIA 6300
By efiste2 in forum Video ConversionReplies: 1Last Post: 30th Oct 2007, 02:51
Statistics
Newest guides
Latest tool updates
New media comments
