VideoHelp.com Forum
  1. Hello,
    It's the first time I try to capture DV video.
    All is working fine with Windv.
    I can open my video in any encoder or in virtualdub.
    I just have a question.
    Why when I open the video in virtualdub, it indicates that the audio samplign rate is 32000 hz.
    Why not 44100 or 48000 hz ??
    Thanks.
  2. Member JimJohnD's Avatar
    The camera's default is 32, yes I know it's stupid. It's set that way because the camera supports a 'voice over' feature that requires the data space. EVERYONE usually resets it to 48K as that is what you need for DVDs. When you render your existing footage you'll have to have it convert the 32K into 48K. Check your cameras manual to change the audio setting.
  3. Member stars's Avatar
    You can change the audio with VirtualDub....
    But in the future set the camera to capture the audio in 48kHz (16bit)
    stars....
  4. Thanks for the tip.
    Now, is it better to use the resampler in tmpg xpress 4 or use the resampler from avisynth or using audacity ???????
  5. Member stars's Avatar
    Its hard to say which one is the better.
    Try tmpg or VirtualDub...
    audacity gives me a corrupt time line (maybe this have been fixed)...
    Anyway I would use VirtualDub.
    stars...
  6. For quality,
    Is it better to install a DV codec and use Avisource in avisynth or use DirectShowSource with the Microsoft Internal DV Codec ????
    Thanks.
  1. Is it OK to use 24p capture all the time?
    By turk690 in forum Editing
    Last Post: 29th Aug 2011, 12:56
  2. capture and watermark a video at the same time ?
    By momo1984 in forum Video Streaming
    Last Post: 4th Aug 2010, 21:15
  3. Replies: 16
    Last Post: 23rd Apr 2008, 14:16
  4. Replies: 1
    Last Post: 18th Sep 2007, 10:12
  5. Capture time
    By galehickey in forum Capturing
    Last Post: 2nd Jul 2007, 22:15
