It plays fine in WMP (with Nero Video Decoder). Here is the info from MPC. I have both DivX and Xvid installed. What's missing here?
Thanks!
Media Type 0:
Video: MPEG4 Video 480x352
AM_MEDIA_TYPE:
majortype: MEDIATYPE_Video {73646976-0000-0010-8000-00AA00389B71}
subtype: Unknown GUID Name {7634706D-0000-0010-8000-00AA00389B71}
formattype: FORMAT_MPEG2_VIDEO {E06D80E3-DB46-11CF-B4D1-00805F6CBBEA}
bFixedSizeSamples: 1
bTemporalCompression: 0
lSampleSize: 1
cbFormat: 174
Thread: MP4 file: missing codec in MPC
Here is from MediaInfo. I do have QuickTime installed.
Format : MPEG-4
Format/Info : ISO 14496-1 Base Media
Format/Family : MPEG-4
File size : 73.8 MiB
PlayTime : 26mn 39s
Bit rate : 387 Kbps
StreamSize : 595 KiB
SpecialPlaybackRequi : QuickTime 6.0 or greater
〆nc : ZJMEDIA MP4/3GP/MOV Encoder v1.0
Video #0
Codec : MPEG-4 Visual
Codec settings/BVOP : No
Codec settings/QPel : No
Codec settings/GMC : 0
Codec settings/Matri : Default
PlayTime : 26mn 39s
Bit rate : 256 Kbps
Width : 480 pixels
Height : 352 pixels
Aspect ratio : 4/3
Frame rate : 23.976 fps
Resolution : 8 bits
Chroma : 4:2:0
Interlacement : Progressive
StreamSize : 48.8 MiB
Writing library : XviD0039
Audio #0
Codec : AAC LC
Codec/Info : AAC Low Complexity
PlayTime : 26mn 38s
Bit rate : 128 Kbps
Channel(s) : 2 channels
Sampling rate : 24 KHz
Resolution : 16 bits
StreamSize : 24.4 MiB
Looks like xvid video with aac audio and encoded with winavi(zjmedia). Does other mp4 work in mpc? I use haali media splitter and ffdshow and most mp4 works fine in mpc then.
I have no problem with AVI files with divx or xvid. This file has mp4 suffix and it seems to be different. I am not sure how MPC works so I went into option to fiddle around with filters. Turned off internal MP4/MOV and added external Xvid decoder. The XVid decoder has the major and subtype already -- I can't find where to put formattype. MPC plays just the audio but no video.
I am guessing here: is this a problem b/c the muxing (guessed from the word splitter)? ffdshow sounds like a general purpose video decoder. Which one would you recommend me to try first?
Thanks!
Installed haali media splitter. Nothing changes. Try to add it as external filter but no difference. Do I need ffdshow?
Any explanation on how these things work together?
Thanks!
MP4 file out of sync in VLC, not in MPC-HC
By sardonis in forum Software PlayingReplies: 1Last Post: 24th Apr 2012, 11:21 -
A required codec is missing-MP4, to fix please read www.copytrans.net
By rocky12 in forum Newbie / General discussionsReplies: 3Last Post: 7th Sep 2011, 11:07 -
cant determine missing codec for wmv file
By brdhsby5 in forum Newbie / General discussionsReplies: 1Last Post: 19th Nov 2009, 00:50 -
Video track header missing in MP4 file
By MaNuHelp in forum EditingReplies: 6Last Post: 17th Apr 2009, 10:23 -
Sanyo HD1000 MP4 File joining - codec problems
By 737 in forum Camcorders (DV/HDV/AVCHD)Replies: 4Last Post: 1st Apr 2008, 13:26
