  1. I've tried several times now to burn a DL disc that I created on my own, and works fine on my computer in dvd mode but won't burn to a disc. My drive is a Benq DW1625, which does support burning DL discs (although for some reason when i insert a blank, my drive thinks its a blank cd for whatever reason, but whatever)
    Anyways, once it gets to a step called "generating dvd high compatibility borders" it stops and aborts itself and wont continue. I've tried nero and a few other smaller burning programs and i get the same problem everytime and I have no idea why it wont let me burn to disc.
    Here's what dvd shrink gave me when the error occured, perhaps maybe you guys can understand it better than me.
    1A20-8203-0133-2123-9327-0044*
    Windows XP 5.1
    IA32
    WinAspi: File 'Wnaspi32.dll': Ver=4.71 (0002), size=45056 bytes, created 11/21/2005 1:48:21 AM
    ahead WinASPI: File 'C:\Program Files\Ahead\Nero\Wnaspi32.dll': Ver=2.0.1.74, size=164112 bytes, created 11/2/2004 1:54:32 PM
    NT-SPTI used
    Nero API version: 6.6.1.15
    Using interface version: 6.3.1.4
    Installed in: C:\Program Files\Ahead\Nero\
    Application: ahead\Nero - Burning Rom
    Internal Version: 6, 6, 1, 15
    Recorder: <BENQ DVD DD DW1625> Version: BBIA - HA 1 TA 0 - 6.6.1.15
    Adapter driver: <IDE> HA 1
    Drive buffer : 2048kB
    Bus Type : default (0) -> ATAPI, detected: ?
    === Scsi-Device-Map ===
    DiskPeripheral : WDC WD3200JB-00KFA0 atapi Port 0 ID 0 DMA: On
    CdRomPeripheral : BENQ DVD DD DW1625 atapi Port 1 ID 0 DMA: On
    === CDRom-Device-Map ===
    BENQ DVD DD DW1625 D: CDRom0
    AutoRun : 1
    Excluded drive IDs:
    WriteBufferSize: 83886080 (0) Byte
    ShowDrvBufStat : 0
    BUFE : 0
    Physical memory : 2045MB (2095084kB)
    Free physical memory: 1583MB (1621116kB)
    Memory in use : 22 %
    Uncached PFiles: 0x0
    Use Inquiry : 1
    Global Bus Type: default (0)
    Check supported media : Disabled (0)
    29.10.2007
    NeroAPI
    9:12:08 AM #1 Phase 112 File APIProgress.cpp, Line 275
    DVD-Video files reallocation started
    9:12:08 AM #2 Phase 114 File APIProgress.cpp, Line 275
    DVD-Video files reallocation completed (no file modified)
    9:12:08 AM #3 Phase 111 File APIProgress.cpp, Line 275
    DVD-Video files sorted
    9:12:08 AM #4 Text 0 File SCSIPTICommands.cpp, Line 403
    LockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL
    9:12:08 AM #5 Text 0 File AudioCompilationImpl.cpp, Line 842
    DRM: StartDrmRecording(RealRec:1, ImageRec:0, Copies:1)
    DRM: Beginning burn process.
    9:12:08 AM #6 ISO9660GEN -11 File geniso.cpp, Line 3312
    First writeable address = 0 (0x00000000)
    9:12:08 AM #7 ISO9660GEN -11 File geniso.cpp, Line 3312
    9:12:08 AM #8 Text 0 File Burncd.cpp, Line 3316
    Turn on Disc-At-Once, using DVD media
    9:12:08 AM #9 Text 0 File DlgWaitCD.cpp, Line 281
    Last possible write address on media: 4173823 (927:30.73, 8151MB)
    Last address to be written: 3751999 (833:46.49, 7328MB)
    9:12:08 AM #10 Text 0 File DlgWaitCD.cpp, Line 293
    Write in overburning mode: NO
    9:12:08 AM #11 Text 0 File DlgWaitCD.cpp, Line 2616
    Recorder: BENQ DVD DD DW1625, Media type: DVD+R9 Double Layer
    Disc Manufacturer ID: RITEK, Media Type ID: S04, Product revision number: 66
    Disc Application Code: 0, Extended Information Indicators: 0
    9:12:08 AM #12 Text 0 File DlgWaitCD.cpp, Line 459
    >>> Protocol of DlgWaitCD activities: <<<
    9:12:08 AM #13 Text 0 File ThreadedTransferInterface.cpp, Line 814
    Setup items (after recorder preparation)
    0: TRM_DATA_MODE1 ()
    2 indices, index0 (150) not provided
    original disc pos #0 + 3752000 (3752000) = #3752000/833:46.50
    relocatable, disc pos for caching/writing not required/ required
    -> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 3752000 blocks [BENQ DVD DD DW1625 ]
    9:12:08 AM #14 Text 0 File ThreadedTransferInterface.cpp, Line 1013
    Prepare recorder [BENQ DVD DD DW1625] for write in CUE-sheet-DAO
    DAO infos:
    MCN: ""
    TOCType: 0x00; Session Closed, disc fixated
    Tracks 1 to 1:
    1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 7684096000, ISRC ""
    DAO layout:
    __Start_|____Track_|_Idx_|_CtrlAdr_|_RecDep_______ ___
    0 | lead-in | 0 | 0x41 | 0x00
    0 | 1 | 0 | 0x41 | 0x00
    0 | 1 | 1 | 0x41 | 0x00
    3752000 | lead-out | 1 | 0x41 | 0x00
    9:12:08 AM #15 Text 0 File SCSIPTICommands.cpp, Line 208
    SPTILockVolume - completed successfully for FCTL_LOCK_VOLUME
    9:12:09 AM #16 Phase 24 File APIProgress.cpp, Line 275
    Caching of files started
    9:12:09 AM #17 Text 0 File Burncd.cpp, Line 4158
    Cache writing successful.
    9:12:09 AM #18 Phase 25 File APIProgress.cpp, Line 275
    Caching of files completed
    9:12:09 AM #19 Phase 36 File APIProgress.cpp, Line 275
    Burn process started at 2.4x (3,324 KB/s)
    9:12:09 AM #20 Text 0 File ThreadedTransferInterface.cpp, Line 2717
    Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
    9:12:09 AM #21 Text 0 File DVDPlusDualLayer.cpp, Line 631
    L0 Data Zone Capacity set to 1876208 (1CA0F0h, 3664MB) -> OK, confirmed setting
    9:12:09 AM #22 CDR -1205 File DVDPlusDualLayer.cpp, Line 658
    Burning Layer 1
    9:12:09 AM #23 Text 0 File DVDPlusDualLayer.cpp, Line 668
    Start writing layer 1 at address 0 (0h)
    Recording mode: unknown Recording Mode
    9:12:09 AM #24 Text 0 File Cdrdrv.cpp, Line 8737
    ---- DVD Structure: Physical Format Information (00h) ----
    Media Type: 0, Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
    Book Type: DVD+R DL (14), Part Version: 1.0x (1)
    Disc Size: 120 mm, Maximum Rate: <not specified> (F h)
    Number of Layers: 2, Track Path: Opposite Track Path (OTP), Layer Type: recordable
    Linear Density: 0,293 um/bit, Track Density: 0,74 um/track
    Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW)
    End Physical Sector Number of Data Area: FCFFFF h
    End Sector Number in Layer 0: 1FA0F0 h (LBN: 1CA0F0 h, 3664 MB)
    Data in Burst Cutting Area (BCA) does not exist
    Disc Application Code: 0 / 0 h
    Extended Information indicators: 0 h
    Disc Manufacturer ID: RITEK...
    Media type ID: S04
    Number of Physical format information bytes in use in ADIP up to byte 63: 64
    Media Specific [16..63]:
    00 00 00 52 49 54 45 4B - 00 00 00 53 30 34 42 40 ...RITEK...S04B@
    25 25 37 10 00 2C 6C 00 - 2C 6C 20 1F 0C 0C 14 14 %%7..,l.,l......
    02 01 01 20 00 20 1F 0C - 0C 14 14 02 01 01 20 00 ................
    9:12:09 AM #25 Text 0 File DVDR.cpp, Line 6510
    Drive: BENQ DVD DD DW1625
    Book Type request [gen]: DVD-ROM, write to EEPROM
    Changing the Book Type was finished successfully, return code 0
    9:12:09 AM #26 CDR -1211 File DVDR.cpp, Line 5636
    Book Type set to: DVD-ROM
    9:12:09 AM #27 Text 0 File DVDPlusRW.cpp, Line 666
    Start write address at LBA 0
    DVD high compatibility mode: Yes
    9:13:00 AM #28 SPTI -1176 File SCSIPassThrough.cpp, Line 178
    CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1176)
    Sense Key: 0x03 (KEY_MEDIUM_ERROR)
    Sense Code: 0x72
    Sense Qual: 0x01
    CDB Data: 0x2A 00 00 00 00 00 00 00 20 00 00 00
    Sense Area: 0x70 00 03 00 00 00 00 12 00 00 00 00 72 01
    Buffer x190c0040: Len x10000
    0x00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    9:13:00 AM #29 CDR -1176 File Writer.cpp, Line 281
    Session fixation error
    D: BENQ DVD DD DW1625
    9:13:00 AM #30 SPTI -1176 File SCSIPassThrough.cpp, Line 178
    Sense Key: 0x05 (KEY_ILLEGAL_REQUEST)
    Sense Code: 0x72
    Sense Qual: 0x03
    CDB Data: 0x5B 01 05 00 00 00 00 00 00 00 00 00
    Sense Area: 0x70 00 05 00 00 00 00 12 00 00 00 00 72 03
    9:13:00 AM #31 Phase 127 File APIProgress.cpp, Line 275
    Generating DVD high compatibility borders
    9:13:00 AM #32 Text 0 File DVDR.cpp, Line 6510
    9:13:00 AM #33 CDR -1176 File WriterStatus.cpp, Line 162
    9:13:00 AM #34 TRANSFER -24 File WriterStatus.cpp, Line 162
    Could not perform end of Disc-at-once
    9:13:00 AM #35 Phase 38 File APIProgress.cpp, Line 275
    Burn process failed at 2.4x (3,324 KB/s)
    9:13:00 AM #36 Text 0 File AudioCompilationImpl.cpp, Line 867
    DRM: DRM burn session terminated.
    9:13:00 AM #37 Text 0 File AudioCompilationImpl.cpp, Line 896
    DRM: Closing entire DRM handling. Bye.
    9:13:00 AM #38 Text 0 File SCSIPTICommands.cpp, Line 253
    SPTIDismountVolume - completed successfully for FSCTL_DISMOUNT_VOLUME
    9:13:30 AM #39 SPTI -600 File SCSIPassThrough.cpp, Line 178
    CdRom0: SCSIStatus(x00) WinError(121) NeroError(-600)
    Sense Key: 0x00 (KEY_NO_SENSE)
    Sense Code: 0x00
    Sense Qual: 0x00
    CDB Data: 0x1B 00 00 00 02 00 00 00 00 00 00 00
    Sense Area: 0x00 00 00 00 00 00 00 00 00 00 00 00 00
    9:13:47 AM #40 SPTI -1176 File SCSIPassThrough.cpp, Line 178
    Sense Code: 0x72
    Sense Qual: 0x01
    9:13:47 AM #41 Text 0 File Cdrdrv.cpp, Line 9945
    DriveLocker: UnLockVolume completed
    9:13:47 AM #42 Text 0 File SCSIPTICommands.cpp, Line 403
    UnLockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL
    Existing drivers:
    File 'Drivers\CDRALW2K.SYS': Ver=8.0.0.212 , size=9464 bytes, created 3/7/2007 7:51:00 PM
    File 'Drivers\ASPI32.SYS': Ver=4.71 (0002) built by: WinDDK, size=16512 bytes, created 11/21/2005 1:48:21 AM
    File 'WNASPINT.DLL': Ver=V1.18, size=57344 bytes, created 12/21/2006 2:50:02 PM
    File 'Drivers\PXHELP20.SYS': Ver=3.00.56a, size=43528 bytes, created 3/7/2007 7:51:00 PM (Prassi/Veritas driver for win 2K)
    Registry Keys:
    HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
  2. Try IMGBurn and use this guide:
    http://forum.imgburn.com/index.php?s=e5e677a59b0205ee8915c73e2a43f1b7&showtopic=1780
    Not sure but I'll almost bet that will fix your problem.
  3. Member t0nee1's Avatar
    Dec 2006
    Here,where do you think?
    And I would use Verbatim DVD+R DL media.........using IMGBurn as suggested....JMO....
    "I typed the word Google into Google. Guess what came up? Everything."
    "What we've got here is failure to communicate"
  4. Originally Posted by t0nee1
    When I posted earlier I didn't even notice that you were using RITEK...S04 and the (KEY_MEDIUM_ERROR). I doubt that burner has a strategy for that media. Verbatim is the only way to go when it comes to DVD+R DL.
  5. Member [_chef_]'s Avatar
    Nov 2002
    Germany
    For RitekS04 you need a newer DL burner, an actual top notch drive.
  6. Member oldandinthe way's Avatar
    Mar 2006
    With the other crabapples
    "Could not perform end of Disc-at-once"
    Is usually associated with media for which the drive has no write strategy or an improper write strategy.
    Suggest you seek a firmware update. If MCSE supports your drive it might be worth seeing if this media is in the new firmware before you waste any more disks. Also check to see if the Verbatim DVD+R/DL's strategy is present.
    Write strategy is great and all, but it still comes down to the fact that Ritek makes a lot of crappy media, DL being one of them.
  8. Member oldandinthe way's Avatar
    Mar 2006
    Don't disagree that Ritek DL is crap. But to stand a chance at burning it you need a correct write strategy.
    Instead of using "higher quality" media as a bandaid for bad hardware, I believe one should use the best hardware we can, to get the full benefit of the media. And use our existing hardware in a manner in whcih it can perform at its best.
    The OP may perform firmware updates and still fail to burn Ritek DL but he will have given it a reasonable try. Otherwise it comes down to Lordsmurf says "Ritek is crap".
